Then I started FSX SE and the displays did not light up.
1) Install GIT into c:\goflight and not into the NGX directory and not into c:\program files (x86)\goflight
2) Unzip the attached file into c:\goflight so that GFDev.dll appears in c:\goflight
3) Start FSX SE and load up the NGX to the Virtual Cockpit.
4) Confirm that the MCP PRO is not working
5) Start GIT using run as Administrator. If the MCP PRO does not light up, enable it in the MCP PRO tab within GIT.
6) Test the MCP PRO.
I am very happy for such a good support
