Tom
Tom
Installation Code. Press CTRL+C to copy to clipboard!
bm9rZXkKbm9rZXkKbm9rZXkKbm9rZXkKMDAzMzAtODAwMDAtMDAwMDAtQUEzNTMKbm9rZXkKRGVmYXVsdCBzdHJpbmcKbm9rZXkKbm9rZXkKbm9rZXkKbm9rZXkKQkZFQkZCRkYwMDAzMDZGMgpub2tleQpub2tleQomJiZHb0ZsaWdodCBJbnRlcmZhY2UgVG9vbCAoMSk=
OK
Sorry to use this forum. The one I am suppose to use says error cant use. Something about a problem with my computer. that's the same problem I have had before. I answered the question about how man eyes a person has.
2 and then it gave me the error.
Here is what it said.
I have reset your install counts. Please try again.
Can you also start a new discussion for different subjects, otherwise the information gets lost for other people
I have two sims on my computer. P3D and FSX SE. I was getting errors running the Database tools on P3D so I figured I'd give FSX SE. Default database no updates. No problems except for the Our Airports Database. As I said before the Program just exits. So I updated the NavData for FSX SE and now I get errors for each database update.
Locks at this point. With P3D.
https://flic.kr/p/29YB6B1
Faulting application name: NavData_Tool.exe, version: 1.2.1.0, time stamp: 0x5b4f1b13
Faulting module name: KERNELBASE.dll, version: 10.0.17134.165, time stamp: 0xfa43f4b2
Exception code: 0xe0434352
Fault offset: 0x0010ddc2
Faulting process id: 0x1af0
Faulting application start time: 0x01d44c49e1d4823f
Faulting application path:
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 20877e15-dc76-4f9c-8cdf-b15c2a593d9d
Faulting package full name:
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.UriFormatException
at System.Uri.CreateThis(System.String, Boolean, System.UriKind)
at System.Uri..ctor(System.String)
at DynamicClass.(System.String)
at A..(System.String)
at A..()
Exception Info: System.Reflection.TargetInvocationException
at System.RuntimeMethodHandle.InvokeMethod(System.Object, System.Object[], System.Signature, Boolean)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(System.Object, System.Object[], System.Object[])
at System.Reflection.RuntimeMethodInfo.Invoke(System.Object, System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo)
at GalaSoft.MvvmLight.Helpers.WeakAction.Execute()
at GalaSoft.MvvmLight.Command.RelayCommand.Execute(System.Object)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(System.Windows.Input.ICommandSource, Boolean)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(System.Windows.Input.MouseButtonEventArgs)
at System.Windows.UIElement.OnMouseLeftButtonUpThunk(System.Object, System.Windows.Input.MouseButtonEventArgs)
at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(System.Delegate, System.Object)
at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean)
at System.Windows.UIElement.ReRaiseEventAs(System.Windows.DependencyObject, System.Windows.RoutedEventArgs, System.Windows.RoutedEvent)
at System.Windows.UIElement.OnMouseUpThunk(System.Object, System.Windows.Input.MouseButtonEventArgs)
at System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs)
at System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs)
at System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs, Boolean)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs)
at System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr, System.Windows.Input.InputMode, Int32, System.Windows.Input.RawMouseActions, Int32, Int32, Int32)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr, MS.Internal.Interop.WindowMessage, IntPtr, IntPtr, Boolean ByRef)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Window.ShowHelper(System.Object)
at System.Windows.Window.Show()
at System.Windows.Window.ShowDialog()
at A.
.[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.__Canon ByRef, Boolean)
at A..()
at System.Windows.Controls.MenuItem.InvokeClickAfterRender(System.Object)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at DynamicClass.(System.Object)
at A.
.(System.Object)
at A.P.P()
I'm looking at Kernelbase.dll its in that folder and its the same version listed. Only difference is Caps Lock.
The other is C:\Programs\Nav Data Tool\NavData_Tool.exe This is not where I have this app installed.
