Had a quick look at David's most recent config (In the "Downloads" section) in combination with the GIT 2.011, and all looks fine.
Will do a test flight tomorrow.
The GoFlight hardware has a limitation in that, unlike the real EFIS/MCP, it does not have dual rotaries for the minimums, Baro and bank angle. When I first built the profile it was not possible to mimic two rotaries on the one physical rotary.
Your question got me interested in the changes that Steve has implemented. There are now different events that can be triggered for rotaries whether you're pushing the rotary or not when turning simultaneously.
Zibo has provided commands that can be attached to the PushedClockwise and PushedAnticlockwise events. The downside is that the push event is triggered first before the other two events are triggered so for the Baro rotary when you push it will change to STD and turning will change it from IN to HPA and back. If you let go and do it again the Baro will change to the number when pressed and then IN to HPA and back when rotated.
(In the Zibo mod you can set the default Baro setting in the Aircraft configuration).
I don't think the settings will help in this case trying to block the initial push as they apply across all of the devices.
I've uploaded my latest EFIS and MCP-PRO xml files. Download and import into GIT and see what you think.
today I downloaded Zibos v3.30 and the IAS and EFIS Range Selector don't work.
Could you have a look at this?
Martin
Hope this can be fixed asap.
I'm just downloading Zibo 3.30b now. I'll give it a try tonight and have a look at the issues you've raised.
Which DREDataRefs.txt and Commands.txt are you using, David?
Do you have any bespoke events in showing in Detective? If you do, press the big red X and get rid of them first, then press the import icon (next to the big red X) and select the XML to import the bespoke events. Let me know if there are any errors.
I am clicking the import icon then choosing your b738_gfmcpro-0.xml file and then after choosing that it does not show any bespoke events
"I don't know what is isuue. I didn't touch code/datarefs for EFIS and IAS.
Code and datarefs are the same in all releases 3.29 and 3.30 (for EFIS/IAS).
