GIT PMDG 777X Beta Bug Reporting Thread
Please report all bugs with the beta release of the Goflight Interface Tool in this thread.
The latest beta can be found here: https://www.dropbox.com/s/r89szr8vqs0o37k/Goflight%20Interface%20Tool%202-1-2-0.zip?dl=0
This discussion has been closed.
On the MCPpro every knob turn causes the numbers to increase or decrease by 5. So if my headings is 360 and I turn slowly the heading knob clockwise it goes to 005, next turn will be 010. Same with counter-clockwise, and same for all knob functions. Also rapid turn causes a multiple of 5, either direction.
Also I can get the lights to work with the toggle T8, but I can not get any data on the light status to light up the LED. I have restarted GFIT every time I change a light setting, but still no LED function.
Also, does the MCPpro work like the MD11, the displays do not show on the MCPpro but it will work on the 777 MCP? If that is correct, then nothing, if not, then the displays on the MCPpro only show 000 but work the MCP on the 777. However it works as listed above.
Thank you for all your work on this..
Terry
Hi Terry,
Is GFConfig configured so that the MCP PRO is set to compatible add-on? Can you also confirm you are using the beta and not an old version off the main product page.
The beta seems to have merged with the last GFIT whan I downloaded it, should that not be?
The first thing I did when I created a 777 profile in the GF software was to make sure the MCPpro was set to compatible add-on.
Terry
Also any idea on how to get the leds to indicate the state of the landing lights and other lights. I tried the same as the MD11 and the 737 and nothing works the LEDS. The switch works T* toggle works the lights just not showing the light on status with the LED. I have tried all the combos in the light state and nothing.
I will try the updated SDK that I have not downloaded yet.
Terry
I understand the gear position light will not work but does the landing light indicator and taxi and nav indicator work?
Sorry for all the questions
Terry
I just copies the saved items back into the c:goflight/"anything" goflight interface module and the go flight Interface tool folder in the document section. That returned all my settings back. Should I roll the beta driver back to the original driver I had, which was the last goflight driver you had out?
Terry
Hi Terry,
I have managed to recreate the 5 increment problem. Its to do with control acceleration in the sim. The NGX handled it automatically, but the 777 doesn't. I'll get an updated version out in a couple of hrs.
New version released:
https://www.dropbox.com/s/8urlhmxmy0zj1in/Goflight%20Interface%20Tool%202-1-1-0.zip?dl=0
Terry
Terry
Thanks for all you do..
Terry
It works great, all my current PMDG settings stayed with the new beta...So far I have programmed a few lights and small items.
Suggestion. Can you create the landing light as a group function like the switches for the APU and such. The landing lights require 3 different buttons and that eats a lot of switches I would like to keep some for other items.
THANK YOU...
I can not find the button to donate. Since you made 3 items to work with the PMDG I would like to donate again as a way to say thank you.. (disregard I found it..Thanks for the program I will let you know on items)
Terry
Thanks Steve. You obviously spend more time programming so we can spend more time flying than you. Very much appreciated.
Gnacino
