MCPPRO Altitude knob doesn't work
I just install GIT on P3D V4.4 on the PMDG 737, and for some reason the only knobs that work are IAS and Heading bug. the rest of the knobs and push buttons do not work when I move it on the MCP Panel but work and change when I used the mouse on the A/C Panel, I will appreciated some help. thanks in advance.
Pedro.
I have found no problems and everything is working fine with both P3D versions of GIT with 4.4 and the NGX.
I would make sure you have configured everything correctly (especially GFConfig as it has different tabs for different flight sims) by following the steps here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/14-installation.html
If you still have the issue after this and you do have 3 green LED's on the status tab, follow the steps in the section titled "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes or dashes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/41-faq/70-faq.html
I have the same problem in FSX.
I followed all your instructions.
What should I do ?
Altitude, CMD, disengage and F / D side of co-pilot
Help me.
