leonardo md80 config install
as instructed by Brian T. i unzipped the md80 config into the gfit folder in my documents for p3dv4. it does not work. is there another way to make this happen. what is the correct installation proceedure please?
  • ill ask another way. Is there anyone who has the maddogx and goflight mcpro with efis working correctly in p3dv4? if so please tell me how to do it.
  • ---- Brian Thibodeaux wrote:
    The only requirement is to unzip all the contents of the zip file
    into My Documents\GoFlight Interface Tool The GFIT tool at this point
    automatically reads the profile data. The only time you need to use
    the import button is if you want separate EFIS panel functionality.
    yes I read the install instructions, and followed them with no results. then followed brains instructions with no results . are you willing to look at my setup if I can send screenshots to you?
  • sorry I misspelled Brian's name. No disrespect intended.
  • additionally, when I follow the install instructions and use the wizard button and select the config zip file, immediately both gfit and wizard windows disappear. every time.. could there be a p3dv4 version or maddogx version discrepancy here??? is there an answer to this somewhere?
    Brian has done it wrong. What he has done there would wipe out all other aircraft configs as I'm assuming he has simply copied and pasted the main config files. If he hasn't then GIT doesn't just detect the files and import them.
    He needs to export them properly if you are going to get it to work.
    If you give me a link to the download I can double check what he has done.
  • Thank you Steve, the link is on the pollypot software downloads page, under git aircraft configs (fsx/p3dv4),at the very bottom of the page.(Leonard MD-80 P3Dv4 (MCP PRO and MCP) v1 by Brian Thibodeaux).
  • I missed that :D
    Leave it with me.
  • any word on md80 ?
    I haven't got round to it yet. Its my list, don't worry.
  • no sweat do your thing.
  • should I now give up hope?
  • Sorry, I had replied, but it was showing up as draft so I must have forgot to click send. See below:
    I have looked at the files and they seem OK to me, but I cannot test them as I don't have the aircraft. If the wizard isn't working, try importing manually. Go into Detective and import the MaddoxX.xml file. Detective should now have Bespoke Events in it. Then go to the MCP PRO tab and import the MaddogX_GFMCPPRO-0.xml file which should configure the MCP PRO. Make sure the MCP PRO is enabled in GIT, then quit GIT and then restart it.
  • im not good at this kind of thing but ill give it my best try. Ill let you know
    thanks.
  • im jumpin up and down . it all works great. my wife is looking at me like im nuts. so what. she already knew, thank you so much. well worth waiting for.
  • I cannot manually install the .zip. I am not sure I understand the import process. I get these error msg.
    After import. Is this right? https://share.icloud.com/photos/0un3jr_6ISR6fZGo7wN4VBn2A
    Enabled: https://share.icloud.com/photos/0un3jr_6ISR6fZGo7wN4VBn2A
    Error: https://share.icloud.com/photos/0LTczdvujfcK6vRe15C_WkWWQ
    THanks
  • Then go to the MCP PRO tab and import the MaddogX_GFMCPPRO-0.xml file is when I get the error and it looks like only one event is imported from the .xml file, but this may be correct. I do not know.
