Problem with T8 switch and PMDG 737 Battery
I'm trying to program a GoFlight T8 switch to operate the master battery on the PMDG737-800. I have got as far as it toggling the battery on/off but the LED remains on for both actions. I would have expected it to go off when the battery is switched off.
I hope the attached screenshot will help. I'm not sure if I need to program a separate action for the OFF status but having tried it it didn't work. The Toggle option seems to work but not for the light.
Ray (Cheshire, England)
https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/36-configuring-goflight-devices-additional-information-pmdg-ngx-77x-747x.html
I'm confused. I'm using the 64-bit GIT version just in case that makes a difference. v3.6.5.3
Is it possible to execute two commands on a single switch? In the case of the battery switch it would be useful to be able to program the cover guard too. That is currently handled via a button command in FSUIPC.
Only by writing a short Lua script and assigning it to your switch. E.g. https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/43-lua/130-lua-pmdg-ngx-example.html
That way the LED always illuminates and all actions are performed for on and off. Job done!
