GF46 not displaying
Hi, I have 11 goflight modules on my sim (P3dv4.4 PMDG 737 800NG,) using GIT. When I switched from Windows 7 to Windows 10, all of them work except for the GF46. The GF46 is on the list of 11 modules, but the display is blank. When you press "identify", nothing happens. You can change all the settings for the module, mine are set to Nav2, Nav2, DME1, Dme2, but they will not display. I have tried setting it in GF config for P3d, with the exact same result. It shows up on the picture, but will not display. I did notice though, that even though it is not displaying on the module, the numbers do change on the simulator. Lastly, I hooked it up to a my old computer with FSX and GFconfig. This computer is completely independent from the one with all my other modules. On that computer it displays perfectly. Your help in getting GF46 to display on the module would be greatly appreciated. Thanks Rob
The GF46 and GF166 are notorious for being difficult. I would check you have power management turned off and selective suspend off on the USB ports and hubs in Windows. GoFlight say you are not to use USB 3 ports and hubs for their equipment also.
I would also run Windows8Fixer.cmd as Administrator in the GoFlight drivers directory.
I have a GF45, RP-48 and P8 working correctly also with special detectives. My config is
- xplane latest release
- ZIBO 737 3.34 H release
- pollypot latest release
- GF45, RP48, P8 on separate hub external powered > 2 amps
- Functions on the GF46 : NAV, COM, TXPD, Radio Alt, ALT, SPD, HDG, CRS
I am in contact with John but till now he suggested the usual things which are already suggested in many forum items.
Changed the setup for the GF-46 very simple, only COM1 and NAV1. But still no luck
I emailed Steve about a strange thing that i only discovered in the XML file of the GF-46 which is below this respons.
When i look in the XML from the export of the GF-46 i see error in the xml. One of the functions is doubled in the config on ID 9. When you look in GIT, the GF-46 has only 8 positions for EVENTS!! (so from 0 to 7). In other words, the last is not correct and maybe therefore cause a hang situation on GIT (non addressable range)
This is <Control ID="8".....
Andre
XML Output from GF-46 attached
That isn't an error it is a fake rotary for when the rotary is pushed down.
Ah thanks for explanation. Hopefully John is able to fix the problems on the gf46
Kind Regards,
Andre
