GIT P3d APPLICATION HALTED warning
Hi Steve, hi community,
hope you had a good Easter weekend?
Last night I had a electrical blackout in the whole house while flying.
After power returned I wanted to fly again, but after opening GIT 3.6.6.1 (you sent me) I received a warning window - see attached screenshot.
No chance, even after UN and REinstalling GIT to open... always the same error(s)
This appears only to GIT for P3d, my GIT-Xplane works without any errors on XPL11
PLEASE HELP ME - I have no more ideas!!! :'(
after performing a windows recovery to yesterday´s status I was able to open GIT again.
works normal with standard plane, but when I load PMDG777 GIT freezes, all three status lights from green to off and I can´t even close GIT without task manager.
glad for any help, been hanging in that for hours now...
Alex
found out that there are more problems... something also went wrong in Windows due to the blackout
just UN- and REinstalled all my P3d, right now assigning axes
then reinstall PMDG and Goflight and GIT.
I have all clean installs, and the original file you sent me... should work out fine I guess...
I´ll keep updated
Greetings,
Alex.
little discouraging UPDATE:
After clean install (P3d, GFConfig, GIT3.6.6.1 ) I still get the warning... see attached.
Sim itself runs perfectly, about 70fps with standard plane, PMDG not yet installed.
So what to do next???
Think I get hopelessly lost now
Alex
thanks Steve!
Not even ONE character in there!
New assignments won´t be a problem, as my GIT shows lamps on DIOs when I click on a connector
Keep you informed, thanks so far!
Alex
Any more files to delete?
but I´ve just seen that I can assign a switch or button for the mooney, but no action in the sim
but says synchronising switches and selectors complete!
So where´s the bottleneck here?
deleting PMDG.xml and give it a try
just noticed I had an older Ver. running... (v3.5.something) redone and checking now
Imported my files and things go great so far!
OHP working, P8 working, just the damned GF-166 makes me crazy... the left display won´t change values on swapping frequency - settings should be ok (attached) - IDEA?
I go for intense testing now and then give you a callback upon it!
Thanks meanwhile
Everything´s fine - with your great support, thanks so much Steve!
So now it´s time for extra coffee - see DM!
Alex
