leonardo md80 config install
as instructed by Brian T. i unzipped the md80 config into the gfit folder in my documents for p3dv4. it does not work. is there another way to make this happen. what is the correct installation proceedure please?
The only requirement is to unzip all the contents of the zip file
into My Documents\GoFlight Interface Tool The GFIT tool at this point
automatically reads the profile data. The only time you need to use
the import button is if you want separate EFIS panel functionality.
yes I read the install instructions, and followed them with no results. then followed brains instructions with no results . are you willing to look at my setup if I can send screenshots to you?
Brian has done it wrong. What he has done there would wipe out all other aircraft configs as I'm assuming he has simply copied and pasted the main config files. If he hasn't then GIT doesn't just detect the files and import them.
He needs to export them properly if you are going to get it to work.
If you give me a link to the download I can double check what he has done.
Leave it with me.
I haven't got round to it yet. Its my list, don't worry.
I have looked at the files and they seem OK to me, but I cannot test them as I don't have the aircraft. If the wizard isn't working, try importing manually. Go into Detective and import the MaddoxX.xml file. Detective should now have Bespoke Events in it. Then go to the MCP PRO tab and import the MaddogX_GFMCPPRO-0.xml file which should configure the MCP PRO. Make sure the MCP PRO is enabled in GIT, then quit GIT and then restart it.
thanks.
After import. Is this right? https://share.icloud.com/photos/0un3jr_6ISR6fZGo7wN4VBn2A
Enabled: https://share.icloud.com/photos/0un3jr_6ISR6fZGo7wN4VBn2A
Error: https://share.icloud.com/photos/0LTczdvujfcK6vRe15C_WkWWQ
THanks
