Device =0, Device =1 mixed up
I set up my WP6 modules that Device =0 is set on the "captains" side and Device = 1 is set on the "first officers" side, of my home built cockpit. I did some recent changes where I had to unplug the modules. Now that I plugged them back in, when I start GIT, the buttons for Device =0 display on the "Captains" side, and the Buttons for Device = 1 display on the first officers side. Since they are all programmed to do different things the actions now, do not match the wording on the buttons. Do I have to reprogram everything again, or is there a way to have them revert back to how I originally programmed them?
Rob
Rob
I have no control of the device assignment as the GoFlight drivers decide that. You could edit the xml file in Documents\GoFlight Interface Tool and manually change the device no entries.
