Exit Lights won't illuminate
I'm programming door exits on the Carenado PC12. There are two. A smaller one for pax and a larger one for baggage. Shift+E 1 opens the smaller and Shift+E 2 opens the larger one.
I have programmed those key commands into Detective and created two Bespoke Events. I then assigned one of them to a T8 switch for the front door - Exit 1.
The switch operates the door correctly but I cannot get the LED to illuminate. In the Light Data dropdown I have selected EXIT_OPEN1, Light Action is ON and Light Value is 1.
Monitoring FSUIPC Offset 3367 it correctly shows the value of the exit that is open - 1 - so the selection above seems correct. Any ideas why the LED won't illuminate when the door is open?
I'm using the 32-bit version of GIT because the PC12 is a 32-bit aircraft but fine in P3D v4.5 HF2. The 64-bit GIT couldn't connect to SimConnect presumably for that reason.
Ray (Cheshire, England)
Is it possible Carenado have messed up these exits inside the mdl file? There are two exits - 0 and 1. 0 is the one controlled by Shift+E and the 1 by Shift +E 2. But the light only comes on for exit 1 when EXIT_OPEN1 is used rather than EXIT_OPEN2.
I’ve programmed other actions for this aircraft and they’re fine. Just the flamin’ door light won’t work.
I reverted to a default aircraft in P3D v4.5. The Commander, to try and get the LED on the T8 to illuminate when a door is opened. I just can't get it to work. I've programmed a bespoke event to toggle the left exit. Shift+E 1. The door opens but the LED does not come on. Can you please explain how to make such a simple action work? I've programmed far more complex actions and they work fine. Just the default doors won't work as they should.
I'm also baffled by the number of events recorded when Shift+E 1 is pressed. This is what GIT is recording. Any idea why so many commands are executed?
0000000040 Event: 066389 Event Data: 000000 Event Name: TOGGLE_AIRCRAFT_EXIT
0000000041 Event: 066514 Event Data: 000000 Event Name: ATC_MENU_CLOSE
0000000042 Event: 066514 Event Data: 000000 Event Name: ATC_MENU_CLOSE
0000000043 Event: 066389 Event Data: 000000 Event Name: TOGGLE_AIRCRAFT_EXIT
0000000044 Event: 066514 Event Data: 000000 Event Name: ATC_MENU_CLOSE
0000000045 Event: 066514 Event Data: 000000 Event Name: ATC_MENU_CLOSE
0000000046 Event: 065538 Event Data: 000000 Event Name: SELECT_1
0000000047 Event: 066514 Event Data: 000000 Event Name: ATC_MENU_CLOSE
Is the lvar changing in Detective and staying changed?
Any idea why so many commands would be triggered by Shift+E as shown above?
Incidentally Steve, you need to amend the link to this topic sent in the email. There's no . between www and pollypotsoftware.org.uk
For some reason Simconnect is not pushing the data out. It does it once, when the variable is requested and then completely ignores any changes and thus does not notify GIT that its changed. I'm not sure I can do anything about this. I guess FSUIPC is reading the direct memory location and not relying on Simconnect.
All I can suggest at this point is to create a Bespoke Event that can read the FSUIPC offset. Name it Start and it should contain something along the lines of this so it loops continuously:
:Start
BespokeVar0 = ReadOffset(FSUIPC offset number here)
Sleep(1000)
Goto :Start
And then assign BespokeVar0 as the light data on your T8 LED.
Note that start Bespoke Event only runs when GIT first loads the aircraft, so you will need to quit GIT and start it again to get the start event running.
Thanks for finding the problem and suggestion. Could you talk me through the buttons to press to create a Bespoke Event please? I'm assuming those at the bottom-right of Detective but not sure which.
PS Before clicking ReadOffset, select the BespokeVar0 at the top of the screen under the Bespoke Vars tab.
I'm struggling. I've created a new Bespoke Event and named it Start. I then select Bespoke Var0 from the Lvars box and press Set. It prompts me to enter a numeric value. Doesn't seem logical when I look at your code above. I remove that entry.
If I select Bespoke Var0 and then press Set= a message appears saying to Select a Variable/Dataref above. But which one? Readoffset is not listed anywhere. I remove that entry.
Finally, if I select Bespoke Var0 and then press Readoffset the field used to enter data is blank but the tick mark is enabled. If I press that 0000 appears. If I then enter 3367 (the offset required) and hit OK the entry reads:-
Bespoke Var 0 = Readmem(3367).
That doesn't seem right either. Can't fathom what to do, sorry.
It should display a drop down list of read types but they are all blank. I'm guessing code obfuscation and messed up the list. I'll look into now.
Installed new version and selection of FSUIPC type now available. The critical line is
Bespoke Var 0 = ReadMemUB(3367).
However, despite assigning the T8 switch to Bespoke Var0 whilst the pax door opens the led status doesn't change. Do we need a condition setting? 0 = both exits closed. 1 = Exit1 open. 2 = Exit2 open. 3 = Both Exits open. Those are the values when monitoring that offset.
If 3367=0 then led = off else led = on.
Thoughts?
Is there a way of checking this procedure is reading that offset correctly? Can it be displayed at all?
Also added Start procedure just so you can check it's okay.
Can't follow your last comment, sorry. Yes, I have restarted GIT but despite trying all options the LED will not come on whether exit 1 is open or closed.
Are you basing this on theory or have you coded it as I have and assigned it to a switch?
Just to confirm I want LED to come on when door is open and go off when door is closed.
14:20:41 GoFlight Connection Starting.....
14:20:41 SimConnect Connection Starting.....
14:20:42 SimConnect Message Processing Started
14:20:42 GoFlight Connection Started
14:20:42 SimConnect Connection Started
14:20:42 Aircraft Connection Starting.....
14:20:42 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
14:20:42 SimConnect: Event Received: SIM, 1
14:20:42 SimConnect: Event Received: PAUSE, 0
14:20:45 WinSock: Connected To localhost On Port 27015!
14:20:45 LUA Processor: Started!
14:20:49 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
14:20:49 Aircraft Connection Started
14:20:49 Simconnect Version: 3.4.0.0
14:20:49 Aircraft FullName: Carenado PC12
14:20:49 Synchronising Switches & Selectors .....
14:20:49 LvarNamesUpdated!
14:20:49 Creating Bespoke Vars
14:20:49 Bespoke Vars Created
14:20:49 Importing Bespoke Variables
14:20:49 Bespoke Vars Assigned, Importing Bespoke Events
14:20:49 Bespoke Events Temp Imported
14:20:49 Bespoke Events Imported
14:20:49 Loading Aircraft Settings
14:20:49 GetXMLConfigData
14:20:49 GotXMLConfigData
14:20:49 Loading Power
14:20:49 Loading MCPPRO
14:20:49 Loading EFIS
14:20:49 Loading P8
14:20:49 Loading T8
14:20:49 Loading RP48
14:20:49 Loading MESM
14:20:49 Loading WP6
14:20:49 Loading LGT
14:20:49 Loading LGT II
14:20:49 Loading GF46
14:20:49 Loading GF45
14:20:49 Loading TQ6
14:20:49 Loading DIO
14:20:49 Loading GF166
14:20:49 Loading SECM
14:20:49 Loading Joysticks
14:20:49 Clearing Displays
14:20:49 Reset Data
14:20:49 Aircraft Settings Loaded
14:20:49 Calling Aircraft Changed
14:20:50 Aircraft Changed
14:20:50 LvarNamesUpdated!
14:20:50 Creating Bespoke Vars
14:20:50 Bespoke Vars Created
14:20:50 Importing Bespoke Variables
14:20:50 Bespoke Vars Assigned, Importing Bespoke Events
14:20:50 Bespoke Events Temp Imported
14:20:50 Bespoke Events Imported
14:20:50 Loading Aircraft Settings
14:20:50 GetXMLConfigData
14:20:50 GotXMLConfigData
14:20:50 Loading Power
14:20:50 Loading MCPPRO
14:20:50 Loading EFIS
14:20:50 Loading P8
14:20:50 Loading T8
14:20:50 Loading RP48
14:20:50 Loading MESM
14:20:50 Loading WP6
14:20:50 Loading LGT
14:20:50 Loading LGT II
14:20:50 Loading GF46
14:20:50 Loading GF45
14:20:50 Loading TQ6
14:20:50 Loading DIO
14:20:50 Loading GF166
14:20:50 Loading SECM
14:20:50 Loading Joysticks
14:20:50 Clearing Displays
14:20:51 Reset Data
14:20:51 Aircraft Settings Loaded
14:20:51 Calling Aircraft Changed
14:20:51 Aircraft Changed
14:20:52 Synchronising Switches & Selectors Complete
That's the problem. GIT hasn't been able to connect to FSUIPC. Try disabling your firewall to see if the port needs opening.
16:09:32 GoFlight Connection Starting.....
16:09:32 SimConnect Connection Starting.....
16:09:33 SimConnect Message Processing Started
16:09:33 GoFlight Connection Started
16:09:33 SimConnect Connection Started
16:09:33 Aircraft Connection Starting.....
16:09:33 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:09:33 SimConnect: Event Received: SIM, 1
16:09:33 SimConnect: Event Received: PAUSE, 0
16:09:36 WinSock: Connected To localhost On Port 27015!
16:09:36 LUA Processor: Started!
16:09:40 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
16:09:40 Aircraft Connection Started
Silly question but if all the other switches work and FSUIPC itself works where is the problem? If something wants to access via the Firewall I usually get a prompt to allow or deny. No such prompt has been seen.
I removed the duplicate and fired up P3D and GIT. Still the same message. I even created a new entry in the approved programs in the firewall for GIT and checked private network only. Still no joy.
So if I understand the problem correctly GIT is trying to read the offset in FSUIPC and the firewall is denying access. But why am I not even seeing a message asking if I want to allow access? Been there, done that for lots of other fs-related software. It really is frustrating.
For this to take root, you will need to delete all directories located in
C:\Users\Your Username\AppData\Local\PollyPot_Software
