PMDG NGXu
Appreciate any info about driver for the new PMDG NGXu.
Thank you
Thank you
Log:
10:34:28 GoFlight Connection Starting.....
10:34:28 SimConnect Connection Starting.....
10:34:29 GoFlight Connection Started
10:34:53 SimConnect Message Processing Started
10:34:53 SimConnect Connection Started
10:34:53 Aircraft Connection Starting.....
10:34:54 SimConnect: Event Received: Start
10:34:54 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
10:34:54 SimConnect: Event Received: SIM, 0
10:34:54 SimConnect: Event Received: PAUSE, 0
10:35:25 WinSock: Connection Failed: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:35:25 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
10:35:27 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
10:35:27 Aircraft Connection Started
10:35:27 Simconnect Version: 4.0.0.0
10:35:27 Aircraft FullName: IRIS Raptor Driver
10:35:27 Synchronising Switches & Selectors .....
10:35:27 Synchronising Switches & Selectors: Waiting for SimConnect .....
10:35:27 Prepar3D v4 ini file not found
10:35:27 SimConnect: Event Received: Aircraft Type Changed
10:35:27 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
10:35:27 GoFlight Connection Starting.....
10:35:27 SimConnect Message Processing Finished
10:35:28 SimConnect Connection Starting.....
10:35:28 Creating Bespoke Vars
10:35:28 Bespoke Vars Created
10:35:28 Importing Bespoke Variables
10:35:28 Bespoke Vars Assigned, Importing Bespoke Events
10:35:28 Bespoke Events Temp Imported
10:35:28 Bespoke Events Imported
10:35:29 GoFlight Connection Started
10:35:29 SimConnect Message Processing Started
10:35:29 SimConnect Connection Started
10:35:29 Aircraft Connection Starting.....
10:35:29 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
10:35:29 SimConnect: Event Received: SIM, 0
10:35:29 SimConnect: Event Received: PAUSE, 1
10:36:01 WinSock: Connection Failed: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:36:01 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
10:36:02 Aircraft Connection Started
10:36:02 Simconnect Version: 4.0.0.0
10:36:02 Aircraft FullName: PMDG 737-800NGXu BW
10:36:02 SimConnect: Event Received: SIMSTART, 0
10:36:02 SimConnect: Event Received: SIM, 1
10:36:32 SimConnect: Exception Received: OUT_OF_BOUNDS
10:36:32 SimConnect: Exception Received: ILLEGAL_OPERATION
10:36:33 Send Control Data: Too Many Retries
Aleksandr
Thank you Steve!
I had this issue in the past, and while the fix was simple, I unfortunately can't remember it and could not find reference to the issue in the FAQ's
Any help, is always very much appreciated.
Roberto
Same issue here...all five's..
Ben
New version out that fixes the acceleration issue.
And it does, indeed, work OK.
Thank you for the fast turnover!!
Many regards
Roberto
