PMDG NGXu
Appreciate any info about driver for the new PMDG NGXu.
Thank you
  • Yes , me too. Current Goflight Interface Tool seems not to work wth the new PMDG737NGXu !
  • HaHa I have literally just bought a new base unit. So thought now is a good time to update from my old FSX SE to P3d V4.5. the new PMDG 737ngxu. Came across this issue as you all have stated, But My MCP Pro shows zeros though the MCP on the aircraft is updating followed by the Sim Connect Yellow status. I went through the 8 steps and checked all that with no joy. Its great to hear its not just me. But to confirm we are all in the exact same boat do you guys have zeros on the MCP aswell?
    Log:
    10:34:28 GoFlight Connection Starting.....
    10:34:28 SimConnect Connection Starting.....
    10:34:29 GoFlight Connection Started
    10:34:53 SimConnect Message Processing Started
    10:34:53 SimConnect Connection Started
    10:34:53 Aircraft Connection Starting.....
    10:34:54 SimConnect: Event Received: Start
    10:34:54 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    10:34:54 SimConnect: Event Received: SIM, 0
    10:34:54 SimConnect: Event Received: PAUSE, 0
    10:35:25 WinSock: Connection Failed: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    10:35:25 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
    10:35:27 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
    10:35:27 Aircraft Connection Started
    10:35:27 Simconnect Version: 4.0.0.0
    10:35:27 Aircraft FullName: IRIS Raptor Driver
    10:35:27 Synchronising Switches & Selectors .....
    10:35:27 Synchronising Switches & Selectors: Waiting for SimConnect .....
    10:35:27 Prepar3D v4 ini file not found
    10:35:27 SimConnect: Event Received: Aircraft Type Changed
    10:35:27 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    10:35:27 GoFlight Connection Starting.....
    10:35:27 SimConnect Message Processing Finished
    10:35:28 SimConnect Connection Starting.....
    10:35:28 Creating Bespoke Vars
    10:35:28 Bespoke Vars Created
    10:35:28 Importing Bespoke Variables
    10:35:28 Bespoke Vars Assigned, Importing Bespoke Events
    10:35:28 Bespoke Events Temp Imported
    10:35:28 Bespoke Events Imported
    10:35:29 GoFlight Connection Started
    10:35:29 SimConnect Message Processing Started
    10:35:29 SimConnect Connection Started
    10:35:29 Aircraft Connection Starting.....
    10:35:29 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    10:35:29 SimConnect: Event Received: SIM, 0
    10:35:29 SimConnect: Event Received: PAUSE, 1
    10:36:01 WinSock: Connection Failed: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    10:36:01 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
    10:36:02 Aircraft Connection Started
    10:36:02 Simconnect Version: 4.0.0.0
    10:36:02 Aircraft FullName: PMDG 737-800NGXu BW
    10:36:02 SimConnect: Event Received: SIMSTART, 0
    10:36:02 SimConnect: Event Received: SIM, 1
    10:36:32 SimConnect: Exception Received: OUT_OF_BOUNDS
    10:36:32 SimConnect: Exception Received: ILLEGAL_OPERATION
    10:36:33 Send Control Data: Too Many Retries
  • Any update regarding new driver for NGXu ?
  • I check here pretty well daily ,cause i'm not buying the new Xu until its out. Sounds like Pete over at FSUIPC is updating for this aircraft also .
  • Me to Louis, however was doing a general upgrade with a new computer and I hadn't even realised NGXu was a very new download and now I'm re-framing from the sim until I can get the MCP Pro going again.
  • I too am waiting for GIT to support the NGXu for my GF MCP Pro and EFIS. In the meantime, to my great surprise, using the VC's MCP with the mouse is not as bad as I remembered ... but still not as natural as my MCP Pro.
  • GIT has been updated with NGXu support.
    Aleksandr :)
  • Cheers Steve :)
  • And it works flawlessly! Hooray!!
    Thank you Steve!
  • On the first proper" flight after the excitement, I have found that all MCP Pro knobs increase/decrease in "fives" not in single digits. This applies to all the windows of the MCP Pro as well as the EFIS (altimeter setting). If I turn the corresponding knobs in the cockpit itself (VC) then the numbers increase/decrease in single digits and the numbers of the MCP windows are updated correctly, matching those found in the sim.
    I had this issue in the past, and while the fix was simple, I unfortunately can't remember it and could not find reference to the issue in the FAQ's
    Any help, is always very much appreciated.
    Roberto
    Roberto
    Same issue here...all five's.. :(
    Ben
    YEAH!!! Santa came early!!!
  • Hi Roberto,
    New version out that fixes the acceleration issue.
  • Perfect!
    And it does, indeed, work OK.
    Thank you for the fast turnover!!
    Many regards
    Roberto
