WinSock: Connection Failed: 127.0.0.1:27015
Hello,
i have a problem with my MCPPro with the GoFlight Interface Tool. After a Systemcrash the MCP will not work with my P3D.
After the a restart of my Computer the Softwar GoFlight Interface doesn't start, so ich have reinstall this Software. Now Goflight will start but it do not work with the p3d.Maybe the program can't connecting to 127.0.0.1:27015 see log
22:45:55 SimConnect Message Processing Finished
22:45:55 GoFlight Connection Starting.....
22:45:56 SimConnect Connection Starting.....
22:45:56 GoFlight Connection Started
22:45:57 SimConnect Message Processing Started
22:45:57 SimConnect Connection Started
22:45:57 Aircraft Connection Starting.....
22:45:57 PMDG SDK option is OK in Prepar3D v4
22:45:57 SimConnect: Event Received: Aircraft Type Changed
22:45:57 SimConnect: Event Received: SIM, 1
22:45:57 SimConnect: Event Received: PAUSE, 0
22:45:57 SimConnect Message Processing Finished
22:45:57 GoFlight Connection Starting.....
22:45:58 SimConnect Connection Starting.....
22:45:58 Creating Bespoke Vars
22:45:58 Bespoke Vars Created
22:45:58 Importing Bespoke Variables
22:45:58 Bespoke Vars Assigned, Importing Bespoke Events
22:45:58 Bespoke Events Temp Imported
22:45:58 Bespoke Events Imported
22:45:58 GoFlight Connection Started
22:45:59 SimConnect Message Processing Started
22:45:59 SimConnect Connection Started
22:45:59 Aircraft Connection Starting.....
22:45:59 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:45:59 SimConnect: Event Received: SIM, 1
22:45:59 SimConnect: Event Received: PAUSE, 0
22:46:02 WinSock: Connection Failed: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:27015
22:46:02 LUA Processor: Connect Exception - Unable To Connect!
22:46:02 Aircraft Connection Started
22:46:02 Simconnect Version: 4.3.0.0
22:46:02 Aircraft FullName: PMDG 737-600NGX
22:46:02 Synchronising Switches & Selectors .....
22:46:05 Synchronising Switches & Selectors Complete 22:45:55 SimConnect Message Processing Finished
i hope you can help me...
thx
tobi...
thx
tobi...
20:49:31 GoFlight Connection Starting.....
20:49:31 SimConnect Connection Starting.....
20:49:32 SimConnect Message Processing Started
20:49:32 GoFlight Connection Started
20:49:32 SimConnect Connection Started
20:49:32 Aircraft Connection Starting.....
20:49:32 PMDG SDK option is OK in Prepar3D v4
20:49:32 SimConnect: Event Received: Aircraft Type Changed
20:49:32 SimConnect: Event Received: SIM, 1
20:49:32 SimConnect: Event Received: PAUSE, 0
20:49:32 GoFlight Connection Starting.....
20:49:32 SimConnect Message Processing Finished
20:49:33 SimConnect Connection Starting.....
20:49:33 Creating Bespoke Vars
20:49:33 Bespoke Vars Created
20:49:33 Importing Bespoke Variables
20:49:33 Bespoke Vars Assigned, Importing Bespoke Events
20:49:33 Bespoke Events Temp Imported
20:49:33 Bespoke Events Imported
20:49:34 GoFlight Connection Started
20:49:34 SimConnect Message Processing Started
20:49:35 SimConnect Connection Started
20:49:35 Aircraft Connection Starting.....
20:49:35 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:49:35 SimConnect: Event Received: SIM, 1
20:49:35 SimConnect: Event Received: PAUSE, 0
20:49:37 WinSock: Connected To localhost On Port 27015!
20:49:37 LUA Processor: Started!
20:49:37 Aircraft Connection Started
20:49:37 Simconnect Version: 4.3.0.0
20:49:37 Aircraft FullName: PMDG 737-800NGXu SSW
20:49:37 Synchronising Switches & Selectors .....
20:49:46 Global LUA Event Running
20:49:46 Global Aircraft LUA Event Running
20:49:46 Synchronising Switches & Selectors Complete
20:51:38 GoFlight Connection Starting.....
20:51:38 SimConnect Message Processing Finished
20:51:38 SimConnect Connection Starting.....
20:51:39 GoFlight Connection Started
20:51:39 SimConnect Message Processing Started
20:51:40 SimConnect Connection Started
20:51:40 Aircraft Connection Starting.....
20:51:40 PMDG SDK option is OK in Prepar3D v4
20:51:40 SimConnect: Event Received: Aircraft Type Changed
20:51:40 SimConnect: Event Received: SIM, 1
20:51:40 SimConnect: Event Received: PAUSE, 0
20:51:40 SimConnect Message Processing Finished
20:51:40 GoFlight Connection Starting.....
20:51:41 SimConnect Connection Starting.....
20:51:41 Creating Bespoke Vars
20:51:41 Bespoke Vars Created
20:51:41 Importing Bespoke Variables
20:51:41 Bespoke Vars Assigned, Importing Bespoke Events
20:51:41 Bespoke Events Temp Imported
20:51:41 Bespoke Events Imported
20:51:41 GoFlight Connection Started
20:51:42 SimConnect Message Processing Started
20:51:42 SimConnect Connection Started
20:51:42 Aircraft Connection Starting.....
20:51:42 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:51:42 SimConnect: Event Received: SIM, 1
20:51:42 SimConnect: Event Received: PAUSE, 0
20:51:44 WinSock: Connected To localhost On Port 27015!
20:51:44 LUA Processor: Started!
20:51:44 Aircraft Connection Started
20:51:44 Simconnect Version: 4.3.0.0
20:51:44 Aircraft FullName: PMDG 737-800NGXu SSW
20:51:44 Synchronising Switches & Selectors .....
20:51:53 Synchronising Switches & Selectors Complete
20:53:13 SimConnect: Event Received: SIMSTOP, 0
20:53:13 SimConnect: Event Received: SIM, 0
20:53:20 SimConnect: Event Received: SIMSTART, 0
20:53:20 SimConnect: Event Received: SIM, 1
