After Systemcrash the MCP doesn't work
Hello,
i use Goflight MCPPRO with p3d pmdg 737. After a Systemcrash the MCPPro doesn't work. I have change the usb-slots without a positive result and i set windows to last rescue point. I have uninstall and reinstall the GIT but its no positive result. Is there a way to delete all drivers and registry keys? I think Windows had a wrong MCP-driver and so the GIT can't start the MCP correctly...
i hope you can help
tobi...
  • You can try renaming Documents\GoFlight Interface Tool so GIT starts with no config. You will need to re-enable the devices in GIT.
  • Hi Steve, i had try this but the mcp can't start...
  • Can you post your GIT log. Do the switches and rotaries work. Is the MCP enabled in GIT?
  • here ist the log. switches and rotaries doesn't work. sometimes there are strokes in the display
    21:11:10 GoFlight Connection Starting.....
    21:11:10 SimConnect Connection Starting.....
    21:11:11 SimConnect Message Processing Started
    21:11:11 GoFlight Connection Started
    21:11:11 SimConnect Connection Started
    21:11:11 Aircraft Connection Starting.....
    21:11:11 PMDG SDK option is OK in Prepar3D v4
    21:11:11 SimConnect: Event Received: Aircraft Type Changed
    21:11:11 SimConnect: Event Received: SIM, 1
    21:11:11 SimConnect: Event Received: PAUSE, 0
    21:11:11 GoFlight Connection Starting.....
    21:11:11 SimConnect Message Processing Finished
    21:11:12 SimConnect Connection Starting.....
    21:11:12 Creating Bespoke Vars
    21:11:12 Bespoke Vars Created
    21:11:12 Importing Bespoke Variables
    21:11:12 Bespoke Vars Assigned, Importing Bespoke Events
    21:11:12 Bespoke Events Temp Imported
    21:11:12 Bespoke Events Imported
    21:11:13 GoFlight Connection Started
    21:11:13 SimConnect Message Processing Started
    21:11:13 SimConnect Connection Started
    21:11:13 Aircraft Connection Starting.....
    21:11:13 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    21:11:13 SimConnect: Event Received: SIM, 1
    21:11:13 SimConnect: Event Received: PAUSE, 0
    21:11:15 WinSock: Connected To localhost On Port 27015!
    21:11:15 LUA Processor: Started!
    21:11:15 Aircraft Connection Started
    21:11:15 Simconnect Version: 4.3.0.0
    21:11:15 Aircraft FullName: PMDG 737-800NGXu SSW
    21:11:15 Synchronising Switches & Selectors .....
    21:11:30 Synchronising Switches & Selectors Complete
  • hello Steve, now i have solved the problem!! i start the pmdg in cold and dark mode - maybe the mcp can't initalize. now with another panel state and the mcp is working...
  • That's weird. I'll add to my list to check.
