Is the key of GIT P3Dv4 also valid for the 64-bit version?
The instruments do not start automatically. There is also no security question when starting P3D. If I then start the GFDevP3Dv4.exe manually, the instruments work. But after about 5 minutes they turn off.
  • The key works for both.
    Have you disabled power management in Windows 10 for hubs and USB devices as it sounds like Windows is turning them off.
