MCP Parameterization
Gentlemen, I use the system P3D v3 and only flight with the pmdg 737 800. I plugged the MCP into one of the motherboard USB and downloaded the latest software with the drives. Opening GF config setei Compatible add on and for simulator P3D v3. I open the simulator and in MCP nothing happens. Hora is left with the lights on and the numerical window lights on and vice versa. Please help me. Clarify what else I should do for MCP to work correctly.
Have you enabled the MCP in GIT?
Mr. Steve, thanks for the return. Excuse me. My computer skills are minimal. What is GIT and how do I activate it. Thank you very much for your patience and help.
On GIT all lights are green as seen on the screenshot.
Here is the log.
Then check the FAQ entry titled "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes or dashes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
As I was assembling a new equipment and acquired a MCP pro, I was trying to calibrate it on the P3D V3, even given the determination I also acquired the GoFlight Interface Tool P3Dv4 64Bit. Now with the new computer and Prepar3D V4, doubts and problems have returned. First of all I ask for excuses for the insistence, but without your valuable help, I will not succeed. I strictly followed the steps provided by Support for the installations. I first downloaded the GFconfig 2.28.0 software in the C: Program Files directory. I opened it, and besides adding the Prepar3D Simulator, I added Compatible Addon. Then I downloaded the Interface and put it in the same Directory and a message came up that there was already a file with the same name and if that was what I wanted. From the instructions I read, I understood that I did and downloaded both programs in the same folder. Is correct? They asked to later go to Users Appdata Prepar3D and make the modification that I insert below
: <? xml version = "1.0" encoding = "Windows-1252"?>
Launch
dll.xml
False
False
GoFlifgt Interface Module
false
C: \ Program Files \ Goflight \ Goflight Interface Module dll
FSUIPC 5
False
C: \ Program Files \ Lockheed Martin \ Prepar3D v4 \ Modules \ FSUIPC5.dll
as_connect
False
as_srv \ as_btstrp.dll
Is correct?
Well, afterwards I opened the prepar and did not receive any security messages from the simulator. I tried to open the Interface and received a message when I went to put the authentication key, which had too many attempts. Error 202. I am at this stage and I ask for help, please.
Launch
dll.xml
False
False
false
C:\Program Files\Goflight\Goflight Interface Module dll
FSUIPC 5
False
C:\Program Files\Lockheed Martin\Prepar3D v4\Modules\FSUIPC5.dll
as_connect
False
as_srv\as_btstrp.dll
I sent to Technical Support, request for permission to register passwords.
I have reset your install count, so try activating again.
It has been released or accessed from the interface. I lowered the and connected to the lights, they turn green. No configuration appears on the left side of the MCP Pro and a compatible add-on is also available. When the LCP configures the MCP, it remains as lights on and as numeric windows are turned off. Turning on the P3D v4 and configuring a flying plane, the PMDG 737 800 or the MCP remains the same. Lights on and windows with numbers, off and none of the buttons active and no sign of life on the aircraft. I say again that I tried to follow all the steps in the manual provided. When I entered APPdata in the Prepar folder, it is registered that I would receive a message when turning on the simulator, that there was a modification, but I did not receive this message. I look forward to your valuable help.
the only procedure i did was to edit the dll.xml file and as i mentioned, when i turned on the simulator i did not receive a message to run. Does GIT have other steps to be taken? I'm sorry but I'm a total layman in computer science and everything seems so difficult. Give me a step by step that I will do everything that is determined. If you find it interesting to delete everything I've done so far and start from scratch.
