MCP Parameterization
Gentlemen, I use the system P3D v3 and only flight with the pmdg 737 800. I plugged the MCP into one of the motherboard USB and downloaded the latest software with the drives. Opening GF config setei Compatible add on and for simulator P3D v3. I open the simulator and in MCP nothing happens. Hora is left with the lights on and the numerical window lights on and vice versa. Please help me. Clarify what else I should do for MCP to work correctly.
    Have you enabled the MCP in GIT?
  • Mr. Steve, thanks for the return. Excuse me. My computer skills are minimal. What is GIT and how do I activate it. Thank you very much for your patience and help.
  • GIT is short for GoFlight Interface Tool. Get the flight sim started so that the virtual cockpit is visible, then select the MCP or MCP PRO tab, click the combo box next to Device and select Device 0, then change from DISABLED to ENABLED. Quit and restart GIT and test.
  • Hi. I did that and the rotary switches are working. But all the numbers and leds are off. When I rotate the knobs on the MCPPRO, the numbers change in the simulator, but they doesn't apear on the MCPPRO. All black.
    On GIT all lights are green as seen on the screenshot.
    Here is the log.
    13:33:49 GoFlight Connection Starting.....
    13:33:49 SimConnect Connection Starting.....
    13:33:49 SimConnect Message Processing Started
    13:33:49 PMDG SDK option is OK in Prepar3D v3
    13:33:49 PMDG SDK option is OK in Prepar3D v4
    13:33:49 SimConnect: Event Received: Aircraft Type Changed
    13:33:49 SimConnect: Event Received: SIM, 1
    13:33:49 SimConnect: Event Received: PAUSE, 0
    13:33:49 GoFlight Connection Started
    13:33:49 SimConnect Connection Started
    13:33:49 Aircraft Connection Starting.....
    13:33:49 SimConnect Message Processing Finished
    13:33:50 SimConnect Connection Starting.....
    13:33:50 Aircraft Processor: SubscribeToSimObjectEvent Failed
    13:33:50 Creating Bespoke Vars
    13:33:50 Bespoke Vars Created
    13:33:50 Importing Bespoke Variables
    13:33:50 Bespoke Vars Assigned, Importing Bespoke Events
    13:33:50 Bespoke Events Temp Imported
    13:33:50 Bespoke Events Imported
    13:33:51 SimConnect Message Processing Started
    13:33:51 SimConnect Connection Started
    13:33:51 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    13:33:51 SimConnect: Event Received: SIM, 1
    13:33:51 SimConnect: Event Received: PAUSE, 0
    13:33:51 SimConnect: Exception Received: UNRECOGNIZED_ID
    13:33:51 SimConnect: Exception Received: DUPLICATE_ID
    13:33:51 GoFlight Connection Started
    13:33:52 WinSock: Connected To localhost On Port 27015!
    13:33:52 LUA Processor: Started!
    13:33:52 Aircraft Connection Started
    13:33:52 Simconnect Version: 4.3.0.0
    13:33:52 Aircraft FullName: PMDG 737-800NGX WL
    13:33:52 Synchronising Switches & Selectors .....
    13:33:57 Global LUA Event Running
    13:33:57 Global Aircraft LUA Event Running
    13:33:57 Synchronising Switches & Selectors Complete
    13:34:22 WinSock: Connection Failed: Não é possível ler os dados da conexão de transporte: Uma tentativa de conexão falhou porque o componente conectado não respondeu
    corretamente após um período de tempo ou a conexão estabelecida falhou
    porque o host conectado não respondeu.
    13:34:22 LUA Processor: Connect Exception - Unable To Connect!
  • Please ensure you have followed all the installation steps here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/14-installation.html
    Then check the FAQ entry titled "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes or dashes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
  • Good evening.
    As I was assembling a new equipment and acquired a MCP pro, I was trying to calibrate it on the P3D V3, even given the determination I also acquired the GoFlight Interface Tool P3Dv4 64Bit. Now with the new computer and Prepar3D V4, doubts and problems have returned. First of all I ask for excuses for the insistence, but without your valuable help, I will not succeed. I strictly followed the steps provided by Support for the installations. I first downloaded the GFconfig 2.28.0 software in the C: Program Files directory. I opened it, and besides adding the Prepar3D Simulator, I added Compatible Addon. Then I downloaded the Interface and put it in the same Directory and a message came up that there was already a file with the same name and if that was what I wanted. From the instructions I read, I understood that I did and downloaded both programs in the same folder. Is correct? They asked to later go to Users Appdata Prepar3D and make the modification that I insert below
    : <? xml version = "1.0" encoding = "Windows-1252"?>
    Launch
    dll.xml
    False
    False
    GoFlifgt Interface Module
    false
    C: \ Program Files \ Goflight \ Goflight Interface Module dll
    FSUIPC 5
    False
    C: \ Program Files \ Lockheed Martin \ Prepar3D v4 \ Modules \ FSUIPC5.dll
    as_connect
    False
    as_srv \ as_btstrp.dll
    Is correct?
    Well, afterwards I opened the prepar and did not receive any security messages from the simulator. I tried to open the Interface and received a message when I went to put the authentication key, which had too many attempts. Error 202. I am at this stage and I ask for help, please.
  • ?xml version="1.0" encoding="Windows-1252"?>
    Launch
    dll.xml
    False
    False
    false
    C:\Program Files\Goflight\Goflight Interface Module dll
    FSUIPC 5
    False
    C:\Program Files\Lockheed Martin\Prepar3D v4\Modules\FSUIPC5.dll
    as_connect
    False
    as_srv\as_btstrp.dll
  • Good Morning
    I sent to Technical Support, request for permission to register passwords.
    I have reset your install count, so try activating again.
  • It has been released or accessed from the interface. I lowered the and connected to the lights, they turn green. No configuration appears on the left side of the MCP Pro and a compatible add-on is also available. When the LCP configures the MCP, it remains as lights on and as numeric windows are turned off. Turning on the P3D v4 and configuring a flying plane, the PMDG 737 800 or the MCP remains the same. Lights on and windows with numbers, off and none of the buttons active and no sign of life on the aircraft. I say again that I tried to follow all the steps in the manual provided. When I entered APPdata in the Prepar folder, it is registered that I would receive a message when turning on the simulator, that there was a modification, but I did not receive this message. I look forward to your valuable help.
  • Have you enabled the MCP in GIT?
  • the only procedure i did was to edit the dll.xml file and as i mentioned, when i turned on the simulator i did not receive a message to run. Does GIT have other steps to be taken? I'm sorry but I'm a total layman in computer science and everything seems so difficult. Give me a step by step that I will do everything that is determined. If you find it interesting to delete everything I've done so far and start from scratch.
