MCP Pro with XP11.41 and latest software
Hi there,
Can you please help me?
How do you know if your MCP Pro is broken or actually working?
Is there a test that I can run?
How?
Is it possible for the registry to go corrupt and prevent the device form working properly that only the A/T and IAS works but nothing else?
Any help, suggestions welcome
How?
Is it possibel to link the v15 software or is it in the download section of the home page?
i did not spot it, sorry.
I am unsure how to interpret the error in the log
Apologies for the ignorance
14:07:44 Aircraft Changed
14:07:45 XPlane: Event Received: Sim State 1
14:07:48 Bespoke Start Event Running
14:07:48 BespokeEventProcessor: Task Failed RunLUA(D:\Documents\GoFlight Interface Tool\LUA\global.lua)
14:07:48 Global LUA Event Running
14:07:48 BespokeEventProcessor: Task Failed RunLUA(D:\Documents\GoFlight Interface Tool\LUA\b738\global_aircraft.lua)
14:07:48 Global Aircraft LUA Event Running
14:07:48 Synchronising Switches & Selectors Complete
The windows had a problem that went away after a format and reload, the MCP is working and we are all very happy now.
how to install the new version of GIT for XPlane 11.41 is it necessary to reload the software from its account?
I get stuck every time I want to use GIT I have a message like that there is a new version but that's it ...
best regards
Roland
a big thanks for your good job
bests regards
Roland
