GIT crashed after Start P3Dv5
Hello, I need help Git 3.8.0 crashed after start : GoFlight Worker Thread failed.
08:01:17 GoFlight Connection Starting.....
08:01:17 SimConnect Connection Starting.....
08:01:17 SimConnect Message Processing Started
08:01:17 GoFlight Worker Thread Failed: Die Eingabezeichenfolge hat das falsche Format.
08:01:17 SimConnect Connection Started
08:01:17 Aircraft Connection Starting.....
08:01:18 PMDG SDK option is OK in Prepar3D v5
08:01:18 SimConnect: Event Received: Aircraft Type Changed
08:01:18 SimConnect: Event Received: SIM, 1
08:01:18 SimConnect: Event Received: PAUSE, 0
08:01:18 SimConnect Message Processing Finished
08:01:18 SimConnect Connection Starting.....
08:01:19 SimConnect Message Processing Started
08:01:20 SimConnect Connection Started
08:01:20 Aircraft Connection Starting.....
08:01:20 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
08:01:20 SimConnect: Event Received: SIM, 1
08:01:20 SimConnect: Event Received: PAUSE, 0
08:01:23 WinSock: Connected To localhost On Port 27015!
08:01:23 LUA Processor: Started!
Thanks for help.
Florian
Thanks for help.
Florian
Henk.
Can this is an issue with the Win10 admin rights ?
Looking inside the GoFlight CFG there are not all Module listet but when I am open the GF Config with Admin rights there are all there.
So now I have copy a GF CFG from my P3Dv4 NAS Backup for a test into it and volar it runs
After a PC Restart it is broken again.
Any Ideas ?
Thank you Steve again for Support on that piece of Soft and Hardwae.
