Exec light not working NGXU
Hi , since I downloaded Pmdg 737 NGXU , The exec light stop working physically on the Engravity CDU (first model )
But only in NGXU . Original PMDG 737 NGX works ok . So we can discard setup , anyway :
Baud rate 38400
Right
Firmware
Disconnect TO 10000
Never disconnect Cdu /checked
Sts-bold
Dts-std
ToThld-6
Ddt-100
Cts- underlined
Rts-inverse
Also I had noticed that sometimes I get a slow response form the Cdu mixing info between pages .
The only solution is to go back to another page and try again expecting to work .
As I say this is sometimes but is very frequent.
I didn’t search for help at the beginning since it was a very new software . But now I have version 2.0.4.0 (the newest ) and supposedly it has NGXU support .
I searched on the forum and didn’t find any similar topic .
Any help with this ?
The attachment below is an example of a direct command ....
No exec light was present on the CDU.
Lights as offset or fail work as they should.
Baud rate 38400
Right
Firmware
Disconnect TO 10000
Sts-bold
Dts-std
ToThld-6
Ddt-100
Cts- underlined
Rts-inverse
I’m figuring out how ...
Anyway
As an update I just noticed that anytime the exec light suppose to illuminate the offset light illuminates instead .
I know I said above that those lights where working ok but now I meant with than that they illuminate .
Exec light won’t illuminate with anything (just on NGXU)
Right now I just made a lateral offset and i noticed that offset light doesn’t work as well .
In resume
The offset light illuminates when the exec light supposed to . And when the offset light suppose to illuminate it is off .
Not sure if I can make some other findings . Since I’m testing this new version .
I made another finding , lights in general , while performing a light test, only the OFST LIGHT comes on .
no call no fail no msg no exec .
only offset light comes on . but still having the main problem .
Any estimated for a fix?
Thanks for your help .
