How to clear a setting? No option to remove once set? (X-Plane)
How can you "clear" an assignment after setting it - so that it subsequently doesn't do anything?
When you first access an option the dropdown selected item is empty but once set there is no option to re-select the blank assignment from the list of items in the dropdown - nor can I find a NO_EVENT parameter or something similarly named.
This page:
https://pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/35-operating/87-configuring-goflight-devices.html
has a screenshot that implies there is a "_NO_DATA" parameter but it's not in any of the lists
(GF-46 / RP-48)
