GF-166 programming
Hello I have a problem to configure the GF-166 in the MSFS2020 for my purpose.
I want the middle button to switch between standby and active
The left button to switch between NAV1 and NAV2
The right button to toggle between Com1 and Com2.
I was able to do this configuration with the original Goflight (FSX) software without any problems.
I ask you to give me the assignments. It does not work with the programmed buttons NAV, COM and ADF. I am desperate.
Best regards, Peterimageimage
  • edited January 2021
    Hello, it would be possible to give me the correct key assignments, according to my request. For you as a professional it is a minor matter. Since I speak German I have a lot of trouble with it. It would be really nice if you would help me.
    best regards Peter
  • It should be automatically configured to do that when you click the NAV or COM button on the GF166. Are you saying the default config is not working?
  • yes in my opinion that doesn't work. I was able to use the original software from goflight. left button change between NAV1 and NAV2, right button change between COM1 and COM2, middle button transfer from standby to active.
    Peter
  • Peter
    I have had the same problem when I first switch on without GIT my GF166 seems to work ok then when I load GIT the dials seem ok until I press the buttons then the module just freezes and I cant get it to work. I have it assigned in the Goflight config tool, coms 1&2 in the right side also I tried it with the same on the left also Nav1&2 on the left with the same result. I have checked the Git settings and I don't have a clue what to set the dials to. Have you had any luck yet.
    Kind Regards
    Bill
  • Hi
    No, it doesn't work for me either. I've tried everything. Unfortunately I don't get any support from Pollypot. They don't take the problem seriously.
    With kind regards
    Peter
  • I notice in the picture above that the GF166's have the older black faces. I have the same issue with a GF166 and a GF46 that are black(and are my oldest hardware). They show up as detected by my PC and by GIT software. However, they remain dark. Even when I click on the "Identify" button in GIT I get nothing.
    I also have two newer GF166's that are the newer gray color. They both work fine. Just throwing it out there. Could this be an issue?
  • Hi
    I notice also that the black modules are GF166A whilst i have the grey as you do but they are marked GF166 no A I don't no if that matters, I have tried all I know with the GF166 which is not a lot as I'm not that up on computer's. I have 9 modules and the MCPPRO which work perfect I just cannot understand why I cant get this new purchase (GF166) to work. Sometimes the lights on the 166 identify when I press the tab on the GIT config but sometimes they don't really strange.
  • I have the black and grey versions and I have seen both work OK in the past. I will check though and come back to you.
  • Hallo Steve
    Wir warten immer noch auf deine Problemlösung.
    Grüsse Peter
  • Still waiting as well and hoping for a solution.
    Dave
  • In the GoFlight drivers there is a readme file which talks about using Windows8Fixer. Try that.
  • Hello Steve
    Your tip is of absolutely no use.
    My concern is very simple.
    The left button must switch between NAV1 and NAV2
    The right button must switch between COM1 and COM2
    The middle button must switch from standby to active.
    It shouldn't be that complicated. It worked in the earlier versions.
    best regards Peter
  • Hello Steve
    Is there really no solution to the GF166A problem. Please let me know the settings. I would be very grateful.
    Best regards
    Peter
  • See the GF166 section here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/22-configuring-goflight-devices-additional-information.html
    Build each config and use the commands mentioned in the above article to switch between the configs.
    If you examine the default settings (when clicking COM or NAV button), you can see an example of them in use when you examine the events for each config on the buttons.
  • Hey Steve
    Your instructions and tips are absolutely useless. Maybe it's because of the translation from English to German. (I'm Swiss) It's all much too complicated. Is it so difficult for you to send me 3 print screens of the programming of the 3 buttons. Button centre, button left and right.
    You could bring great joy to a 72 year old simulator fan.
    Thank you and greetings from Switzerland
    Peter
  • Hi Peter, hope you are keeping well. I have managed to configure my GF-166 as a NAV-COM radio, so I thought I'd share this with you (and everyone else of course). As you know, the GF-166 can have up to 4 different functions or modes of operation. I have it set up as follows:
    1 - NAV1
    2 - NAV2
    3 - COM1
    4 - COM2
    Since the left, right and centre buttons need different assignments depending on which mode you're on, you will need 12 different button assignments (3 x 4) to make this work. Have a look at the attached pdf. I've taken screenshots of all the control assignments you need for each button.
    The rotaries have to be assigned as below. Bear in mind you need 2 settings per rotary (clockwise and anticlockwise):
    Clockwise assignments
    ROTARY_UNPRESSED1 -> NAV1_RADIO_WHOLE_INC
    ROTARY_PRESSED1 -> NAV1_RADIO_FRACT_INC
    ROTARY_UNPRESSED2 -> NAV2_RADIO_WHOLE_INC
    ROTARY_PRESSED2 -> NAV2_RADIO_FRACT_INC
    ROTARY_UNPRESSED3 -> COM_RADIO_WHOLE_INC
    ROTARY_PRESSED3 -> COM_RADIO_FRACT_INC
    ROTARY_UNPRESSED4 -> NAV1_RADIO_WHOLE_INC
    ROTARY_PRESSED4 -> COM2_RADIO_FRACT_INC
    Anticlockwise assignments
    ROTARY_UNPRESSED1 -> NAV1_RADIO_WHOLE_DEC
    ROTARY_PRESSED1 -> NAV1_RADIO_FRACT_DEC
    ROTARY_UNPRESSED2 -> NAV2_RADIO_WHOLE_DEC
    ROTARY_PRESSED2 -> NAV2_RADIO_FRACT_DEC
    ROTARY_UNPRESSED3 -> COM_RADIO_WHOLE_DEC
    ROTARY_PRESSED3 -> COM_RADIO_FRACT_DEC
    ROTARY_UNPRESSED4 -> NAV1_RADIO_WHOLE_DEC
    ROTARY_PRESSED4 -> COM2_RADIO_FRACT_DEC
    Then you need to configure the displays:
    DISPLAY_LEFT1 -> NAV_ACTIVE_FREQUENCY1
    DISPLAY_RIGHT1 -> NAV_STANDBY_FREQUENCY1
    DISPLAY_LEFT2 -> NAV_ACTIVE_FREQUENCY2
    DISPLAY_RIGHT2 -> NAV_STANDBY_FREQUENCY2
    DISPLAY_LEFT3 -> COM_ACTIVE_FREQUENCY1
    DISPLAY_RIGHT3 -> COM_STANDBY_FREQUENCY1
    DISPLAY_LEFT4 -> COM_ACTIVE_FREQUENCY2
    DISPLAY_RIGHT4 -> COM_STANDBY_FREQUENCY2
    See attached a separate pdf with a couple of examples on how to make these assignments for the rotaries and displays.
    As you can see it's a bit tedious to set up, but once you configure it, you can export the config and use it on most standard aircraft.
    Hope this helps!
    Carlos
  • Hello Carlos
    First of all, thank you very much for your work. I tried to program the GF-166 according to your instructions. Part works. But there is still an error somewhere, but I can't find it. Would it be possible to send me your GF166-0.xml via email? I know this is a big request. I'm really thankful to you for that as I'm not progressing anymore.
    My email address: peter.leonhard50@gmail.com
    regards
    Peter
  • Hi Peter, no problem at all! I just sent you the xml file. Maybe my config does not have the exact same functionality you are after. Hopefully you can live with that, or maybe use it as a baseline and tweak it a bit so it behaves exactly as you want.
    Carlos
  • Hello Carlos
    Your configuration works fine. Now I have a payware aircraft Carenado C182 Skyline in which the altitude GF-MPC cannot be adjusted. The display lights up but the rotary button has no effect. I've tried a lot but without success. I hope you have good advice for me.
    Many thanks Peter
    1 - NAV1
    2 - NAV2
    3 - COM1
    4 - COM2
    Hope this helps!
    Carlos
    Hello Carlos
    this post is old but I'll try your settings
    thanks a lot
    Roland
