Running MCP Default GA in P3DV4_5 just fine but not P3DV5
My MCP Pro will not function in the default GF configuration with a GA aircraft, in this case the A2A Beech Bonanza. In P3DV4.5, I see there is the file GFDev64.dll in the LM Modules folder.
There is no modules folder for P3DV5.
The MCP lights all LCD's when I run GFConfig in both V4 and V5 of P3D. However, in V4 as soon as I load the aircraft, my MCP functions just fine. Not so in V5.
Anyone know a way to get my MCP to function for a default aircraft in V5?
I think it has something to do with the above mentinined GFDev64.dll, but of course I'm just clueless.
Any thoughts, anyone...Steve... anyone????
Thanks!!
Thanks!!
GoFlight Interface Module 64.dll
Does the addition of the 64 have a bearing on what I'm doing here?
I can find and edit my P3D dll.xml file per #3 in the instructions, but I believe I would be having it launch an add-on with an incorrect name (the addition of the "64" in the file name). Of if I followed the step it would not find the file because the one it really needs has a 64 at the end of the file name.
Thanks!
In the Users\appdata\roaming\P3Dv5 directory there is no such dll.xml file to edit
THANK YOU Sir! Very much appreciate your help.
Cheers
