Unsure Issues with Bespoke Vars/PMDG or P3d (I think)
My Goflight Interface Tool P3D 64bit software seems to have thrown a wobbly overnight it was working fine yesterday but today its seems to hang itself when i load prepar3d and the PMDG 737 aircraft now and none of my goflight devices are working with it anymore i have attached the log to see if it sheds any light on whats going on.
All my devices are showing in the interface tool fine.?
Any help would be appreciated as I'm pulling my hair out as to what's happened
19:27:47 GoFlight Connection Starting.....
19:27:47 SimConnect Connection Starting.....
19:27:47 GoFlight Connection Started
19:28:16 SimConnect Message Processing Started
19:28:16 SimConnect Connection Started
19:28:16 Aircraft Connection Starting.....
19:28:20 WinSock: Connected To localhost On Port 27015!
19:28:20 LUA Processor: Started!
19:28:24 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
19:28:24 Aircraft Connection Started
19:28:24 Simconnect Version: 4.3.0.0
19:28:24 Aircraft FullName: Generic
19:28:24 Synchronising Switches & Selectors .....
19:28:24 Synchronising Switches & Selectors: Waiting for SimConnect .....
19:28:26 SimConnect: Event Received: Start
19:28:26 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
19:28:26 SimConnect: Event Received: SIM, 0
19:28:26 SimConnect: Event Received: PAUSE, 0
19:28:57 SimConnect: Event Received: SIMSTART, 0
19:28:57 SimConnect: Event Received: SIM, 1
19:29:02 LvarNamesUpdated!
19:29:02 Creating Bespoke Vars
19:29:02 Bespoke Vars Created
19:29:02 Importing Bespoke Variables
19:29:02 Bespoke Vars Import Exception: '.', hexadecimal value 0x00, is an invalid character. Line 1, position 1.
19:29:15 LvarNamesUpdated!
19:29:15 Creating Bespoke Vars
19:29:15 Bespoke Vars Created
19:29:15 Importing Bespoke Variables
19:29:15 Bespoke Vars Import Exception: '.', hexadecimal value 0x00, is an invalid character. Line 1, position 1.
19:29:25 Synchronising Switches & Selectors Complete
  • It looks like your BespokeVariables.xml file is corrupt. Can you check it and if nothing is in it, restore form a backup.
  • Hi Steve
    Thanks for the info butI think I'm screwed as my BespokeEvents, BespokeVariables & PMDG are all empty in both GIT directory and backup :(
    What I can't understand is why the backup directory is the exact same as the root directory what's the point of having a backup directory if the main one writes over it with a corrupt one.
    Now I'm back to the tedious task of processing this all this back in manually, when I get it done I will back it up and move it elsewhere in future so it can't be written over.
