Simconnect Issue with GIT for MSFS
I have recently acquired MSFS 2020. I downloaded the GoFlight Interface Tool for MSFS but when I start it I get a yellow light in the Simconnect panel, but green light in the left and right panels. What is causing this and is there a fix? I have read the posted startup procedure and think I am doing it right. The MCP pro remains blank.
Thanks for any help.
Martin
Martin
Can you help with this?
Thank you again.
Martin
Attached is a screen shot of the MCP pro tab, and the GIT log.
I guess I will need some further guidance.
Thank you.
Martin
Is there something else I can try?
Thanks again for your help.
Martin
I have a same issue with my set up ( simconnect inbound). Could you send to me the link for to install Wasm module in community folder.
Thank you
Jean
