Just Beginning and ...
Hi there,
I have installed the latest GIT for MSFS, and all my GF modules light up.
I have eight of them, and I am operating with Win 10 and MSFS 2020. All modules are connected to USB 2.0
I believe I have correctly imported the GIT MSFS profile for the Daher TBM 930. After starting MSFS and loading the Daher 930 into the sim, and then starting the GIT, the GIT shows the Daher TBM 930 present and all my modules as recognized and with some commands present.
So ....... I am flying the airplane and no inputs are occurring from the GF modules. I can extend and retract gear, flaps and do elevator trim with my HOTAS assignments, but nothing happens when I flip the gear lever, etc. on the LGT.
What do I need to do to activate the GF connection?
Sorry for what must be obvious newbie questions, however I am going to have a ton of them getting started, especially as I get into the custom programming.
Thank you so much for your help.
I really appreciate the interface product you have created!
Best Answer
Have you clicked the FS Default button on the LGT tab. This will configure it with default settings that work with most aircraft. See this for a basic overview with MSFS: https://www.pollypotsoftware.org.uk/vanillaforums/discussion/1436/fs2020-feature-status-and-usage/p1
Thank you so much! Got all the inputs of the LGT working just fine. Gear, flaps, and elevator trim.
I am noticing one thing. I have to be in the cockpit for the GIT to actuate gear, flaps, or trim. If I am outside of the plane and use the GF controls, they do not activate anything. I have tried pressing the 'C' key, however that does not allow the controls to activate in that view, as it would if I were flying with keyboard/ mouse/ HOTAS.
Is there a way to get the GF inputs to activate when in the outside view?
