Can you explain in more detail about where in the checkout process you get stuck or something fails. I have had sales going through via Stripe (Credit Card) and PayPal so there are no technical issues.
What happens is I go through all the steps necessary to make the purchase and when it comes to the final stage of saying which credit card to use I put that information in and then it doesn't go any farther
I have tried it with more than one message of payments like PayPal or credit cards and it does the same thing it just seems to lock up
In an effort to make things as simple as possible I wanted to use the download configuration files for the units that I ha
1 the instruction refers to steps to take for versions of both above and below a certain amount I can't see where I read the version of the software ?
Using the automatic config download again I was trying to as a start get the proper file downloaded for my landing gear trim my LGT
It tells me to download a zip file and but I'm not sure where I
it get it from or what is it file name should be ?
I did find a list of files that were all XML files does it mean that I have to find out which one of those XML files is correct for my LGT or or how do I identify which file to download it ?
It also tells me it's one of the last steps to enable the device well how do I enable it ?
By the way I do get a little bit of information on my LGT the lights come on on it but it is not doing anything within flight Sim
The if it was possible for you to give me just a basic line by line instructions to load that might help if that's possible
Trying to follow the instructions on the computer or on my phone it's quite confusing because of the are multiple links that it says that you should make so it kind of gets confusing and of course the amount of ads that keep coming up doesnt help
Thank you
Norm
Which aircraft and what flight sim are you using?
As I said I'm getting confused about which files I need to download and where to download them from?
I'm also unclear as to how to identify the right files because I get a whole page of XML files
the aircraft I'm using is just a regular 172
fsuipc installed for me to get GIT to work?
My LGT to work
I have W10 and using MSFS2020
Thanks in advance
I am in my 70 s and the grey matter is not like it used to be LOL
Norm
It should now work OK. If the LED's are not lit, simply quit GIT and then restart it.
Which drop down?? the only drop downs are Device Enabled 8 import export
is there anyway you could connect with me and see what is wrong??
I did that but still doesn't work?
Here is a list of all my steps
1) Load GF config (although my version shows FSX???)
2) Highlight LGT (in GFCFG)
3) Load MSF's and load interface tool
4) Click on LGT and enable it?
5) LGT still doesn't work?
6) Restart GIT
7) Still not work
Ref lights on LGT I only get the 3 gear light to come on?
I don't need FSUIPC for this to work, do I ???
Also Is there a GF cfg That is for MSFS 2020?
Thank you
Norm
Use GIT and on the GIT LGT tab, make sure its enabled. Then click the Default FS button on the GIT LGT tab, which will automatically configure the LGT. Quit GIT, then start GIT.
Try following the instructions here: https://www.pollypotsoftware.org.uk/vanillaforums/discussion/1436/fs2020-feature-status-and-usage/p1
I followed all the instructions and I can still not get it to work??
One thing I do notice is that when I click the icon to start GIT, It seems to go to the area where hidden icons are and I get a message to "double click to restore"
Also when I open task mgr, it shows 2 instances of GIT opened??. It does this every tine?? any way it still does not work
16:53:35 GoFlight Connection Starting.....
16:53:35 SimConnect Connection Starting.....
16:53:35 SimConnect Message Processing Started
16:53:35 GoFlight Connection Started
16:53:35 SimConnect Connection Started
16:53:35 Aircraft Connection Starting.....
16:53:35 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:53:35 SimConnect: Event Received: SIM, 1
16:53:35 SimConnect: Event Received: PAUSE, 0
16:53:36 WinSock: Connected To 127.0.0.1 On Port 27016!
16:53:36 LUA Processor: Started!
16:53:36 Aircraft Connection Started
16:53:36 Simconnect Version: 11.0.62651.3
16:53:36 Aircraft FullName: Asobo_C172sp_classic
16:53:36 LvarNamesUpdated!
16:53:36 Awaiting Late Lvar Registrations (30 Second Timeout)
16:53:38 Late Lvars Detected
16:53:38 Late Lvar Detected: LOCAL_milliBar_to_inHg
16:53:38 Late Lvar Detected: XMLVAR_AudioPanel_1
16:53:38 Late Lvar Detected: XMLVAR_Magneto_Starter_IsHeld
16:53:38 Late Lvar Detected: ENG FUEL VALVE:1
16:53:38 Late Lvar Detected: XMLVAR_LeverThrottleHidden1
16:53:38 Late Lvar Detected: XMLVAR_LeverMixtureHidden1
16:53:38 Late Lvar Detected: XMLVAR_YokeHidden1
16:53:38 Late Lvar Detected: XMLVAR_YokeHidden2
16:53:38 Late Lvar Detected: XMLVAR_ElevatorTrim_Switch_1
16:53:38 Late Lvar Detected: XMLVAR_ElevatorTrim_1_SwitchStateTimer
16:53:38 Late Lvar Detected: HANDLING_ElevatorTrim
16:53:38 Late Lvar Detected: ParkingBrake_Position
16:53:38 Late Lvar Detected: XMLVAR_ADF_Frequency_10_Khz
16:53:38 Late Lvar Detected: XMLVAR_ELT_STATE
16:53:38 Late Lvar Detected: XMLVAR_ELT_TEST_TIME
16:53:38 Late Lvar Detected: LIGHTING_STROBE_1
16:53:38 Late Lvar Detected: LIGHTING_NAV_1
16:53:38 Late Lvar Detected: LIGHTING_TAXI_1
16:53:38 Late Lvar Detected: LIGHTING_LANDING_1
16:53:38 Late Lvar Detected: LIGHTING_BEACON_1
16:53:38 Late Lvar Detected: DEICE_Pitot_1
16:53:38 Late Lvar Detected: XMLVAR_IE_Throttle_VR_Handled
16:53:38 Late Lvar Detected: XMLVAR_IE_Throttle_VR_Value
16:53:38 Late Lvar Detected: INSTRUMENT_Altimeter_1
16:53:38 Late Lvar Detected: INSTRUMENT_Course_1
16:53:38 Late Lvar Detected: INSTRUMENT_Course_2
16:53:38 Late Lvar Detected: AS530_Default_MapZoomRange
16:53:38 Late Lvar Detected: AS530_SelectedSource
16:53:38 Late Lvar Detected: AS430_MapZoomRange
16:53:38 Late Lvar Detected: AS430_SelectedSource
16:53:38 Late Lvar Detected: INSTRUMENT_ADF
16:53:38 Late Lvar Detected: LIGHTING_GLARESHIELD_1
16:53:38 Late Lvar Detected: LIGHTING_GLARESHIELD_2
16:53:38 Late Lvar Detected: LIGHTING_PANEL_1
16:53:38 Late Lvar Detected: LIGHTING_PEDESTRAL_1
16:53:38 Late Lvar Detected: LIGHTING_CABIN_1
16:53:38 Late Lvar Detected: LIGHTING_CABIN_2
16:53:38 Late Lvar Detected: XMLVAR_ELT_ACTIVATION_TIME
16:53:38 Late Lvar Detected: AS430_ScreenLuminosity
16:53:38 Late Lvar Detected: AS430_State
16:53:38 Late Lvar Detected: KR87_ScreenLuminosity
16:53:38 Late Lvar Detected: KR87_State
16:53:38 Late Lvar Detected: KT76C_ScreenLuminosity
16:53:38 Late Lvar Detected: KT76C_State
16:53:38 Late Lvar Detected: KAP140_ScreenLuminosity
16:53:38 Late Lvar Detected: KAP140_State
16:53:38 Late Lvar Detected: AutopilotPreflightCheckCompleted
16:53:38 Late Lvar Detected: HourMeter_ScreenLuminosity
16:53:38 Late Lvar Detected: HourMeter_State
16:53:38 Late Lvar Detected: AS530_ScreenLuminosity
16:53:38 Late Lvar Detected: AS530_State
16:53:38 Late Lvar Detected: AIRLINER_MCDU_CURRENT_FPLN_WAYPOINT
16:53:38 Late Lvar Detected: MAP_FP1_NOT_SPECIFIC_COLORS
16:53:38 Late Lvar Detected: AS530_Default_MapShowCursor
16:53:38 Late Lvar Detected: M803_ScreenLuminosity
16:53:38 Late Lvar Detected: M803_State
16:53:38 Late Lvar Detected: MAP_SHOW_TEMPORARY_FLIGHT_PLAN
16:53:38 Late Lvar Detected: FLIGHTPLAN_USE_DECEL_WAYPOINT
16:53:38 Late Lvar Detected: Glasscockpits_FPLHaveOrigin
16:53:38 Late Lvar Detected: Glasscockpits_FPLHaveDestination
16:53:38 Late Lvar Detected: MAP_SHOWN_FLIGHTPLAN_INDEX
16:53:38 Late Lvar Detected: HUD_AP_SELECTED_SPEED
16:53:38 Late Lvar Detected: HUD_AP_SELECTED_ALTITUDE
16:53:38 Late Lvar Detected: KAP140_BARO_Display
16:53:38 Late Lvar Detected: PFD_BRG1_Source
16:53:38 Late Lvar Detected: PFD_BRG2_Source
16:53:38 Late Lvar Detected: PFD_CDI_Source
16:53:38 Late Lvar Detected: GPS_Current_Phase
16:53:38 Late Lvar Detected: Glasscockpit_DmeSource
16:53:38 Late Lvar Detected: XMLVAR_IsDeiceAirFrame
16:53:38 Late Lvar Detected: XMLVAR_IsDeiceAirFrame2
16:53:38 Late Lvar Detected: XMLVAR_CabinAir_Position_1
16:53:38 Creating Bespoke Vars
16:53:38 Bespoke Vars Created
16:53:38 Importing Bespoke Variables
16:53:38 Bespoke Vars Assigned, Importing Bespoke Events
16:53:38 Bespoke Events Temp Imported
16:53:38 Bespoke Events Imported
16:53:38 Loading Aircraft Settings
16:53:38 GetXMLConfigData
16:53:38 GotXMLConfigData
16:53:38 Loading Power
16:53:38 Loading MCPPRO
16:53:38 Loading EFIS
16:53:38 Loading P8
16:53:38 Loading T8
16:53:38 Loading RP48
16:53:38 Loading MESM
16:53:38 Loading WP6
16:53:38 Loading LGT
16:53:38 Loading LGT II
16:53:38 Loading GF46
16:53:38 Loading GF45
16:53:38 Loading TQ6
16:53:38 Loading DIO
16:53:38 Loading GF166
16:53:38 Loading SECM
16:53:38 Loading Joysticks
16:53:38 Clearing Displays
16:53:38 Reset Data
16:53:38 Aircraft Settings Loaded
16:53:38 Calling Aircraft Changed
16:53:38 Aircraft Changed
16:53:38 Synchronising Switches & Selectors .....
16:53:40 Synchronising Switches & Selectors Complete
Above is copy of log
So clicking the icon seems to pit access to to the program into the Hidden icons area?
