See this for the default community folder locations: https://helpdesk.aerosoft.com/hc/en-gb/articles/5023507568925-How-to-locate-the-Community-folder-in-Microsoft-Flight-Simulator
Unzip the whole zip file including the directories into the community folder.
In desperation I went looking for the config panel at Pollypot but found myself downloading the interface software I already have so now I am £29.99 down and no further forward! The EFIS panel is shown and works just fine.
I have a couple of issues I am looking to get resolved. I am using P3Dv4.5 Windows 10 PMDG 737NGX.
1) I believe I pressed on the GF Config file, and now when I open up P3DV4.5 I get dotted lines across the MCP as soon as P3DV4.5 is open. Once I open the PMDG 737NGX the lines turn to 0's. When I then log in to Pollypott GIT, all my modules come to life, but when I try and move tjhe knobs on the MCP, it is as if the old GF config, and Pollypott GIT are both working at the same time. When you turn the knobs, you get all different numbers being displayed, so it is very difficult to know what speed or heading you are on.
2) When I press the Pollypott GIT, it tells me that there is a new version available. I press OK, and then I am up and running. My last version update was Dec 01, 2019. Is there a new version I should be running, and if yes, how do I get it?
3) I also have the Pollypott GIT for FS2020. It was last modified Oct 13, 2020. It does not seem to work very well. Is there a newer version for that as well, with more features?
Looking forward to hearing back from you.
Rob
