MSFS 2024
GIT don't work with 2024. Will it be fixed to work?
your username\AppData\Local\Packages\Microsoft.Limitless_8wekyb3d8bbwe\LocalCache\Packages\Community. Started up FS2024 and then GIT and everything worked.If this doesn't work for you, please provide more info/logs etc.
I will get a new installer out over the weekend, unless other problems are found in the meantime.
But supposedly the current LVARS and Datarefs for FS2020 will work in FS2024.
Will find out in a few hours when the PMDG 737-800 releases.
[SDK]
EnableDataBroadcast=1 to the options. ini files as I did in 2020 but this time it didn't work in 2024 is there a fix to get the Go-Flight MCP working?
This is what the status looks like - all looks good to me but the MCP still will not work - what am I missing?
