Simconnect yellow
Hello,
I have a problem: The Simmconnect LEDs light up yellow as soon as I start the GoFlight interface.
I had this problem before and was able to fix it with your help.
Unfortunately, it's not working this time. I've tried all your suggested solutions. Even GFWindows8Fixer didn't help. I even installed the program manually. I'm at a loss.
I would be very grateful for your help.
Sincerely,
Peter Leonhard
Sincerely,
Peter Leonhard
Best Answer
Hello Peter,
I don’t have either sim so I’m afraid I can’t help further. Make sure you’re running the latest version of GIT.
I’ll tag Steve in the hope he can solve it for you. @admin_pps .Cheers,
Ray (Cheshire, England)
Steve provided help here.
https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-virtual-flight-sim-hardware/62-installation/260-simconnect-networking-configuration.html
Kind regards,
Peter
Then run GFWindows8Fixer also with admin privileges. Then check the GFWindows8Fixer log. Post the contents here.
Simconnect is still showing yellow
Thanks, Peter.
I hope the attachment worked.
Regards, Peter
Choose "Attach File" then click Browse. Find the log file and select Open.
I've attached a sample file which you should be able to open.
Regards, Peter
The name of the aircraft should be visible to the right in GIT which means all is well.
If that doesn’t work please provide as much info as possible. Sim, aircraft selected and a screenshot of GIT.
I have found that GIT runs perfectly in MSFS2020. So it is MSFS2024 that is causing these problems. I am testing in LSZH with a Carenado C-182 RG II. It also does not work with other aircraft (Asobo).
I have attached some files in the hope that you can help me further.
Thank you very much for your great support.
Best regards,
Peter
https://www.pollypotsoftware.org.uk/vanillaforums/discussion/comment/9957#Comment_9957
