Suggestions please
Is there a place to find import configs for GA aircraft?
  • There is one in the forum from a couple of weeks ago and another in the Downloads section of the web site.
  • I am sorry but can you please explain what exactly is meant by device_? As in configuration string? That unit number or setup number? Also same question in regards to control number? Sorry, just confused.. Trying link up To the P8 and 166a and a 45...
  • I'm confused now as well. In what context are you asking these questions?
  • As far as the string...Light Value 1 <--- The set (GF166_DEVICE0_ACTIVECONFIG) value when config 1 is active...sorry..I know I did not explain my question very well..
  • also please..what exactly would ..Controls2 be ?? in this type string...GF166_CONTROLS2
  • Just want to make sure I am understanding the concept of DEVICE0_ and CONTROLS2..thank you for your time.Have a great day. Roger
  • OK, the device is the device number of your GF166. So if you have multiple units you use the relevant variable. If you just have 1 unit you always use DEVICE0 variables.
    The GF166 can have upto 4 configs loaded into it in real time. This is needed for example for the COM radios so that when you press the button to switch between standby and active it loads a different config which swaps the COM radio variables around. The configs are numbered 1 to 4 and ACTIVECONFIG variable will contain a value between 1 and 4 depending on which config has been loaded.
    There is more information here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/22-configuring-goflight-devices-additional-information.html in the GF166 section.
