Thank you Steve
[SDK]
EnableDataBroadcast=1
Edit the 737_Options.ini using notepad and add:
[SDK]
Rename the directory pmdg-aircraft-737 by adding old to it.
Start FS2020 and the pmdg-aircraft-737 should be rebuilt (it will take a few minutes). Get to the 737 cockpit and then quit FS2020.
Start GIT and then FS2020 and see if it updates the ini file correctly.
Peter
You did remember to enable it on the LGT tab? If yes, I'll do some testing on the LGT II tomorrow and come back to you.
