P3D 4.1 anf GFIT
Good afternoon Steve
Just recently I purchased P3D V4.1 also the PMDG 737NGX.
I downloaded the P3D version of GFIT and loaded it with no problems, although I noticed some differences when compared with FSX.
1) When loading the PMDG 737NGX, GFIT appears to load OK but the simconnect light is yellow. The log shows "Simconnect: Exception Received". .The MCP Pro, EFIS and LGT appear to be working OK, The Detective button is also grayed out. I assume this is not a problem.
2) When loading a default aircraft I get 3 green buttons but when I go into detective and do an Events Toggle it does not scroll. The LVARS Toggle scrolls but it's the same LVAR, "Time Clock Start", nothing else.
I Believe I have all the simconnects loaded (4 entries)
My operating system is Windows 10 1709. Build 16299.98
Computer is a I7 8700K
All help is appreciated.
Gordon Graf
Gordon Graf
after you loaded a default aircraft did you try to load a default profile for the MCPPro by hitting the default FS button? Otherwise there is no profile and nothing will happen.
Thanks for your response. I suspected with the PMDG 737 being hard coded that was the issue.
When I refer to default aircraft I'm talking about one of the aircraft that came with P3D in this case the Bonanza. I don't understand what you mean by "load a default profile for the MCPPro by hitting the default FS button".
Thanks again
Gordon
Not all devices have the default fs button.
I did untick "Pause on Task Switch" in P3D so the sim is running.
Can I assume, looking at Robs tutorial, that GFIT in P3D works the same as FSX?
Gordon
Its probably that this aircraft is "quiet". Try pressing a few buttons in the VC and see if anything appears. Move your head view around in the cockpit and this will generate events.
That was it. Thanks to you and Slayer for your help.
Gordon
Best regards
Peter Hecht
If your PMDG aircraft are still not working please do the steps I recommend in this thread: https://www.pollypotsoftware.org.uk/vanillaforums/discussion/722/mcp-pro/p1
Did you fix your problem?
no it is nit fixed. I uninstalled GIT, deleted goflightinterce from the documents, and installed the latest Software Version, still only dashes in the mcp Pro. By the way, after the reinstall og GIT I was not asked to enter my licence again, and when starting prepar3d versiobn 4.1 I was not asked if I trust the interface.
Best regards
Peter
Assuming you have followed in the installation instructions, did you check the 5 things in the FAQ entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
yes, I checked that. But my mcp pro is not even showing zeroes, only dashes..
<Launch.Addon> <Name>GoFlight Interface Module</Name> <Disabled>False</Disabled> <Path>C:\Program Files (x86)\GoFlight\GoFlight Interface Module 64.dll</Path> </Launch.Addon>Thx
22:28:20 GoFlight Connection Starting.....
22:28:20 SimConnect Connection Starting.....
22:28:21 GoFlight Connection Started
22:28:48 SimConnect Message Processing Started
22:28:48 SimConnect Connection Started
22:28:48 Aircraft Connection Starting.....
22:28:50 WinSock: Connected To localhost On Port 27015!
22:28:50 LUA Processor: Started!
22:28:52 FSUIPC: Connection Failed: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:8385
22:28:52 Aircraft Connection Started
22:28:52 Simconnect Version: 3.4.0.0
22:28:52 Aircraft FullName: Generic
22:28:52 Synchronising Switches & Selectors .....
22:28:52 Synchronising Switches & Selectors: Waiting for SimConnect .....
22:28:52 SimConnect: Event Received: Start
22:28:52 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:28:52 SimConnect: Event Received: SIM, 0
22:28:52 SimConnect: Event Received: PAUSE, 0
22:29:14 Prepar3D v3 ini file not found
22:29:14 PMDG SDK option is OK in Prepar3D v4
what is wrong with FSUIPC?
No
22:29:14 SimConnect: Event Received: Aircraft Type Changed
22:29:14 SimConnect Message Processing Finished
22:29:14 GoFlight Connection Starting.....
22:29:14 SimConnect Connection Starting.....
22:29:15 Creating Bespoke Vars
22:29:15 Bespoke Vars Created
22:29:15 Importing Bespoke Variables
22:29:15 Bespoke Vars Assigned, Importing Bespoke Events
22:29:15 Bespoke Events Temp Imported
22:29:15 Bespoke Events Imported
22:29:15 GoFlight Connection Started
22:29:15 SimConnect Message Processing Started
22:29:16 SimConnect Connection Started
22:29:16 Aircraft Connection Starting.....
22:29:18 WinSock: Connected To localhost On Port 27015!
22:29:18 LUA Processor: Started!
22:29:18 Aircraft Connection Started
22:29:18 Simconnect Version: 3.4.0.0
22:29:18 Aircraft FullName: PMDG 737-600NGX
22:29:19 SimConnect: Event Received: Start
22:29:19 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:29:19 SimConnect: Event Received: SIM, 0
22:29:19 SimConnect: Event Received: PAUSE, 1
22:29:56 SimConnect: Event Received: SIMSTART, 0
22:29:56 SimConnect: Event Received: SIM, 1
22:29:56 SimConnect: Exception Received: ERROR
22:29:57 SimConnect: Exception Received: ERROR
22:29:58 SimConnect: Exception Received: ERROR
22:29:59 SimConnect: Exception Received: ERROR
22:30:00 SimConnect: Exception Received: ERROR
22:30:03 Synchronising Switches & Selectors Complete
ok, I will look for the new version and will test it as soon as possible and you will get a feedback. Thank for your support.
Peter
New version of GIT for P3Dv4 is now available. If it doesn't work, download and try the GIT P3Dv4 64Bit.zip file.
nothing has changed with the new Version. Then I tested the 64 bit Version and Registration failed: 202!
Best regards
Peter
Here is the log:
18:38:27 GoFlight Connection Starting.....
18:38:27 SimConnect Connection Starting.....
18:38:29 GoFlight Connection Started
18:38:57 SimConnect Message Processing Started
18:38:58 SimConnect Connection Started
18:38:58 Aircraft Connection Starting.....
18:39:00 WinSock: Connected To localhost On Port 27015!
18:39:00 LUA Processor: Started!
18:39:02 FSUIPC: Connection Failed: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:8385
18:39:02 Aircraft Connection Started
18:39:02 Simconnect Version: 4.1.0.0
18:39:02 Aircraft FullName: Generic
18:39:02 Synchronising Switches & Selectors .....
18:39:02 Synchronising Switches & Selectors: Waiting for SimConnect .....
18:39:03 SimConnect: Event Received: Start
18:39:03 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
18:39:03 SimConnect: Event Received: SIM, 0
18:39:03 SimConnect: Event Received: PAUSE, 0
18:39:34 Prepar3D v3 ini file not found
18:39:34 PMDG SDK option is OK in Prepar3D v4
18:39:34 SimConnect: Event Received: Aircraft Type Changed
18:39:34 SimConnect Message Processing Finished
18:39:34 GoFlight Connection Starting.....
18:39:35 SimConnect Connection Starting.....
18:39:35 Creating Bespoke Vars
18:39:35 Bespoke Vars Created
18:39:35 Importing Bespoke Variables
18:39:35 Bespoke Vars Assigned, Importing Bespoke Events
18:39:35 Bespoke Events Temp Imported
18:39:35 Bespoke Events Imported
18:39:35 GoFlight Connection Started
18:39:36 SimConnect Message Processing Started
18:39:36 SimConnect Connection Started
18:39:36 Aircraft Connection Starting.....
18:39:38 WinSock: Connected To localhost On Port 27015!
18:39:38 LUA Processor: Started!
18:39:38 Aircraft Connection Started
18:39:38 Simconnect Version: 4.1.0.0
18:39:38 Aircraft FullName: PMDG 737-600NGX
18:39:40 SimConnect: Event Received: Start
18:39:40 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
18:39:40 SimConnect: Event Received: SIM, 0
18:39:40 SimConnect: Event Received: PAUSE, 1
18:40:25 SimConnect: Event Received: SIMSTART, 0
18:40:25 SimConnect: Event Received: SIM, 1
18:40:33 Synchronising Switches & Selectors Complete
best regards
Peter
funny, I rotated the knobs of the mcp pro while a standard plane was active and than loaded the 737NGX. Then suddenly the mcp pro was ok! Only the vertivcal speed seems to be erratic; for instance, when turning the wheel to rise the vertical speed, suddenly the speed was going down and vice versa. So it is difficult to select the vertical speed which you want to fly. Could that be a problem with the beta Version?
Best regards and once again thank you for the Support.
Peter
