GIT unresponsive on exit
Problem: Exit XP11 GIT becomes unresponsive
Steps to replicate:
1. Load GIT 2.0.11.0
2. Start XP11
3. Select default 747
4. switch from full screen to window mode and back to full screen
5. exit XP11
see attached picture of the state GIT is in when it becomes unresponsive ... note the GIT windows can't be moved, requires taskmgr to end task OR you have to wait upto 5-10 minutes then GIT will CTD with the follow OS event error log:
Application: GoFlight Interface Tool X-Plane.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at DynamicClass.(System.Object)
at A..(System.Object)
at A.S.App_DispatcherUnhandledException(System.Object, System.Windows.Threading.DispatcherUnhandledExceptionEventArgs)
at System.Windows.Threading.Dispatcher.CatchException(System.Exception)
at System.Windows.Threading.Dispatcher.CatchExceptionStatic(System.Object, System.Exception)
at System.Windows.Threading.ExceptionWrapper.CatchException(System.Object, System.Exception, System.Delegate)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at A. .(System.Object)
at A.S.U()
Faulting application name: GoFlight Interface Tool X-Plane.exe, version: 2.0.11.0, time stamp: 0x5a21869f
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x03432e73
Faulting process id: 0x2178
Faulting application start time: 0x01d38d623806f79d
Faulting application path: F:\GoFlight Interface Tool X-Plane\GoFlight Interface Tool X-Plane.exe
Faulting module path: unknown
Report Id: 811dde20-c939-4359-a391-b15b17dd0f34
Faulting package full name:
Cheers, Rob.
Steps to replicate:
2. Start XP11
5. exit XP11
at A.S.U()
Cheers, Rob.
