21st November: A new version of the GoFlight Interface Tool for FS2020 is now available.
GIT 2-0-16-3
Since updating to GIT version 2-0-16-3 , GIT won't connect to Xplane 11. Log below
Reinstall in c:\GoFlight Interface Tool and after, make sure the GIT plugin is present and try again.
I re-installed GIT to c:\GoFlight Interface Tool and checked the GIT was in the Xplane Plugins folder. I have still the same issue, the GIT plugin works perfectly with most aircraft except the same aircraft as the last time.
I installed a new aircraft onto Xplane and GIT connected with it straight away.
I have also tried enabling and disabling add-on's in the plugin admin one by one to see if they were causing any issues but GIT is still not connecting to the aircraft. I deleted all the config files relating to said aircraft but all the assignment tabs are still disabled, I still get the 3 green lights and all red X's.
There is a GIT folder which installs in my documents folder when installing GIT, is that supposed to be installed there ?
Is there anything else I could try ?
Could you send me on a link for version 2-0-16-2 as I can only download the latest version from the download store.
Is there a way to roll back to 2-0-16-1 without uninstalling the current version as I tried with a fresh install of the -1 version and a load of errors appeared saying there was an updated version ?
Yes I uninstalled version 2-0-16-3 and installed version 2-0-16-1. When I started X-plane a load of error boxes appeared and it said an updated version of GIT was available, it wouldn't run the 16-1 version. I had to then install the 16-3 version again with the same results.
Thanks for your reply. I,m a bit unsure what you need me to do. Do you just require a copy of the GIT script when it's running with Xplane ?
i am attaching the GIT file from My Documents
Just wondering if you found anything out from the GIT file I sent you ?
Would like to know the outcome of this particular case
@bne737lame , I have not got the issue with the GIT not connecting to the AW139 solved yet. I have received no reply to my previous post looking for an update.
