FS2020 Feature Status and Usage
This discussion has been closed.
Is there any chance GF-ATC could be made compatible with MSFS. Not overly concerned with the audio functions (if they are even a part of the programming), but essentially the "SEL" functionality - pushbutton and rotary. Currently I have 3 working functions through FSUIPC.
Thanks in advance
The type initializer for 'A' threw an exception
Secondly , is there a way to let GF-EFIS work (it mention that it is only for PMDG/IFly).
If you still have problems, raise a separate discussion and I will get you up and running.
If all else fails, delete the BespokeEvents.xml in the same directory as above.
I have the last GIT version (MSFS) with 3 green lights, but nothing happens on MCP. Anyone has this issue?
https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/46-beginners-start-here/151-beginners-guide.html
Here make sure you see a mention of the PMDG SDK in the Log tab. If you don't, read this thread: https://www.pollypotsoftware.org.uk/vanillaforums/discussion/1740/pmdg-b737-for-msfs-2020-launch-today-git-support/p1
Bets wishes
The first problem is that the installation of the latest GIT version 4-6-2-0 does not work properly, with the message that the program cannot find the community folder. I can't find the flightsimio.module file either.
I'm also having trouble registering
An error message 202 appears. I have set the language to original English.
I hope you can help me
Greetings Peter
Your install count is fine, so make sure when you copy the User Key you do not have Google translate running or a language selected on the web site.
I have the original Goflight app and drivers installed, should I uninstall it ?. Also I have FSUIPC running at background.
Follow up on your thread here: https://www.pollypotsoftware.org.uk/vanillaforums/discussion/1735/go-flight-interface-face-will-not-load-up#latest
and I can assist you.
At the Pete's Dawson's software site I downloaded the GFDEV64.dll version 2.2.8.0 May 05 2022 and put it in the paid version of FSUIPC7 file that is installed in my "C" drive
In the fs2020 community section where it says -pollypotsoftware-flightsimio-module ,when I open that up it says modules -layout.json and one saying manifedt.json
the file saying modules when open says FlightSimI0ModuleWASM.sasm
I have the latest Go Flight interface tool fs2020.exe 4.6.2.0 date 2022- 05- 28
When I start flight sim and FSUIPC starts up I can see all my 12 Go Flight modules being seen by FSUIPC
When i open up Go flight interface tool, all 3 lights are green ,when I enable my modules and identify them ,the lights on the corresponding modules light up -this is where I'm at, if i had some examples of setting some thing like Master battery, beacon lights, and a few more and setting trim or barometer settings on the rotaries it might be enough to get me going to keep setting the rest, My MCP auto pilot , I can't get going . In P3D i had no trouble setting them up in the PMDG , and the general aircraft we had the Go Flight conf. tool to set them up but you say in FS2020 we don't have it any more . So it seems I'm getting pretty close ---Thanks Louis
2= j'ai téléchargé un fichier GIT 2020 module mais si je mets le dossier modules dans community il n'est pas reconnu dans le " gestionnaire de
contenus " de MSFS ? par contre si je mets directement le fichier « FlightSimIO moduleWASM.wasm » là il est reconnu ! ( est-ce normal ?. Un fichier
"lisez moi" sera le bienvenu !! pour le prochain utilisateur .
3 = Pour l'installation des COM ou des NAV en automatique , une petite vidéo sur "youtube " sera la bienvenu car comme le dit le dicton un "dessin vaut
mieux qu'un "long discours". Je dis cela car je suis en mode basique pour l'informatique et je ne dois pas être le seul, le logiciel est
quand même complexe.
Merci pour l'aide
I have tried several times to configure my T8 and RP48 for the PMDG 737 in MSFS and nothing works.
Then I saw some downloads and I tried to download it and for over an hour it still says, "Saving and restarting.." but nothing.
What am I missing. I really want to use these GF modules I have.
Please help
Have you tried these examples here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/37-configuring-goflight-devices-examples-pmdg-ngx.html
If still no joy, start a new post in Discussions and include your GIT log from the Log tab and provide an example of what you have tried.
Please follow these installation instructions: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/263-installation-fs2020.html
